Hi , i have been trying to fix the above atx psu ,I think it got quite hot , there was a LOT of dust inside the case and i the fan was not turning freely so may be was stopped .
There were some caps on the output which looked questionable so i replaced them all , i have +5 VSB and that is all .
When i connect it to a motherboard and hdd it works for a second then shuts down , if i leave the green wire and com shorted to power on , it works ok .
It uses a SG6105ADZ ic .
not sure where to go from here ..
O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
