A while back, I found a faulty EA-500  on eBay for cheap (starting bid at $0.99), and I thought it would be another fun PSU fixing project. I ended up winning the auction for $3 (not counting the $11.50 for the shipping). So, here is a post about it.
I have to say, sometimes eBay really surprises me with the deals one can find there. My EA-500 came complete with absolutely everything: that is, a box in very good condition, one power cable, an owners manual, and even the complimentary bag of screws. Here are the pictures, if you don't believe me:
https://www.badcaps.net/forum/attach...1&d=1509061896
Clearly this eBay seller cared about his/her computer stuff, as everything is in immaculate condition.
Likewise, the PSU itself was just as clean.
All output wires are 18 AWG, 300V.
But looks can be deceiving! Without even tearing it open, it was easy to spot this:
Perhaps not so obvious on this picture, but right there I was able to see a bad cap. And that shouldn't be surprising - turns out bad caps are quite common for these PSUs. Actually, there are plenty of examples here on badcaps.net as well. For instance, below are two posts made by everell, where he shows the same EA-500 model as mine.
https://www.badcaps.net/forum/showpo...14&postcount=7
https://www.badcaps.net/forum/showpo...15&postcount=8
What I find even more interesting is that his has bulged caps in the same exact spots as mine, and same brand and series too: OST RLX and RLS. The smaller brother of this PSU, the EA-430, also has the same layout and caps, thus the same problems. So this is going to be more or less another recapping thread for the Antec EA-430 and EA-500 models (and possibly EA-380 too?)
Before I open it, let's have a look at the label.
Nice and consistent labeling that looks just like on the review websites.
And now we dig in…
https://www.badcaps.net/forum/attach...1&d=1509062129
… revealing another bulged cap. Other than that, I really like what I am seeing – nice open design with plenty of space for airflow, especially on the primary side. The secondary is a bit cramped, but not that bad and nowhere near as horrible as the Aspire PSU I posted about not too long ago.
Here is a different angle to give an idea about the size of the components:
Looks like the bad cap we saw through the front grille is filter output for the 5VSB circuit. No wonder the seller stated in the auction that the PSU is dead. At least this PSU has a ICE2A0565z PWM-FET offline IC for the 5VSB, which is good. What's not so good-looking is the hack job with that small cap soldered directly to the opto-coupler top-side pins. But it works, so I'm not worried. It just looks... eh…
Next, we observe the primary side:
PFC silicone consists of two PV218N50 MOSFETs, a STTH8506d diode, and a 1N5406 bypass diode. The main PS section is double-forward, again with two PV218N50 MOSFETs. Main transformer has a 35 mm core and the 5VSB a 19 mm one.
Moving onto the secondary side:
We see an exclusive OST-only party. And it looks like some of these “party-goers” had little more than a few drinks, as they are looking a bit “puffy”.
Specifically, the 12V rail cap (OST RLX 16V, 3300 uF, 12.5 mm dia.) on the left is bulging, as is the skinny 8 mm OST RLS behind it (which is for the -12V rail.)
It is interesting to note that this PSU also has a design from 2005, just like the Aspire I posted. BUT! Notice how much cleaner this PSU is. Clearly YoungYear has a long way to go before it catches up to the quality of Seasonic here (if they are even still making PSUs). Speaking of designs, this is Seasonic's S12II platform. PCB is labeled: ATX400W PCB rev 5.
Another short of the secondary, showing something that I don't like:
That little TO-92 transistor with the scorched PCB around it is the drive transistor of the linear fan controller. It is a _______ transistor. Clearly, it is undersized for the 250 mA that the fan is rated for. Did that contribute to cooking these caps? I don't know, but I sure don't like it. In the picture you can also see the fan connector pulled out. I had some trouble disengaging that locking connector. What's worse: as I tried pushing the connector back in, I ended lifting up the traces on the solder side of the PCB. Lame!
Speaking of which, let's have a look at the solder side:
It looks pretty good, except for the few hand-soldered blobs (mostly on the primary side.) Also, some of the component leads were not cut very well and protruded a bit more than I like to see. I actually managed to pierce the skin on my hand quite a few times because of that. But it wasn't as bad as the CWT-built Corsair CX750M and Thermaltake M850W PSUs I posted here – those actually make me want to cry every time I think about doing anything to them.
Sharp eyes may have also noticed in the last picture above where I lifted the traces for the fan connector. Nothing got ripped out, though, so no major damage.
While on the topic of PCBs, here is the receptacle filter board;
And last but not least, I want to make a note of the plastic insulation sheets used in this power supply: they seem to be quite sensitive to heat and easily get darkened. Once that happens, they also become quite brittle. Here is a picture of the one under the PSU's PCB:
Mmmm. Nice and crispy on the upper left corner. Coincidentally, this is where the fan controller's drive transistor is. Who would've thought.
On that note, I forgot to take a picture of the fan, but it is just an-ADDA (get it? ) AD0812HS-A70GL, rated for 12V and 250 mA.
Anyways, let's have the detailed component breakdown now:
Primary Side Summary:
- Four 2.2 nF Y2-class certified caps
- Two Carli X2-class certified caps (0.22 uF + 0.47 uF)
- three common-mode chokes
- GBU806 bridge rectifier (8 Amps @ Tc = 100°C, 600 V reverse voltage)
- PFC section: 1 uF 450V film cap after bridge rect., two PV218N50 MOSFETs, one STTH8506d diode, one 1N5406 diode
- Main filter cap: one Hitachi HP3, 400V, 330 uF, 30 x 40 mm (dia. x h)
- Main PS topology/design: double-forward with two ., two PV218N50 MOSFETs
- Transformers: main with 35 mm core and 5VSB with 19 mm core
- Input wire: 16 AWG, 300V for Live/Neutral and 18 AWG, 600V for ground
ICs
- CM6800 chip for PWM+PFC function
- ICE2A0565z off-line SMPS IC for 5VSB generation
- HY-510N supervisor IC on the secondary side (OVP on 3.3V, 5V, and 12V; UVP on 3.3V and 5V)
- three NEC 2561 optocouplers
- two 431 reference shunts
Secondary Side Summary:
3.3 V rail:
- mag-amp regulated
- ST STPS30L30CT (30 Amp, 30V, TO-220) schottky rectifier
- 1x OST RLX, 10V, 2200 uF, 10 x 20 mm before PI coil
- 1x OST RLS, 10V, 1000 uF, 8 x 20 mm after PI coil
- PI coil: 4-turn, 4 mm core, 14 or 16 AWG
- load resistor: 100-Ohm SMD (3015m)
5 V rail:
- load resistor: 220-Ohm SMD (3015m)
12 V rail:
- SBR30A50CT (30 Amp, 50V, TO-220) schottky rectifier
- 1x OST RLX, 16V, 3300 uF, 12.5 x 25 mm before PI coils
- 2x OST RLS, 16V, 1000 uF, 8 x 20 mm after each PI coil (2 coils for “2” rails)
- PI coils: two 5-turn, 4 mm core, 14 or 16 AWG
- load resistor: 560-Ohm SMD (3015m)
-12 V rail:
- derived from output inductor winding, not main transformer
- 1.5 or 2 Amp (?) diode
- 1x OST RLS, 16V, 1000 uF, 8 x 20 mm before PI coil
- 1x OST RLS, 16V, 220 uF, 6.3 x 11 mm after PI coil
5 VSB rail:
- SB340(?) schottky rectifier
- 1x OST RLX, 10V, 3300 uF, 10 x 25 mm before PI coil
And that is all I have for now. I'll post more pics with the fresh caps when I get to recap this PSU more properly. Right now, I have it recapped temporarily just for testing, and it's working well. The EarthWatts EA-430 that I have also likely needs new caps. Don't know for sure, as I haven't opened it yet. Poor guy is still sitting in a box in the garage since I bought it, which was almost a year ago.
Anyways, these are good PSUs well worth saving.
And now we dig in…
) AD0812HS-A70GL, rated for 12V and 250 mA.Anyways, let's have the detailed component breakdown now:
ICs
3.3 V rail:
- mag-amp regulated
5 V rail:
12 V rail:
-12 V rail:
5 VSB rail:
 Antec EarthWatts EA-430 and EA-500 – an easy bad caps fix
								 Half of the computer problems is caused by bad contacts
 (Why is the ESR increasing?) Either way, my replacement for the 3.3V rail 2200 uF cap was the Nichicon HZ 6.3V, 2200 uF cap that I used temporarily on the 5VSB (I moved it). ESR might not be ideal being so low (7 mΩ), but it’s a mag-amp regulated rail and thus it likely won’t care too much. (Not that the 5VSB did either.)
 Some of you might also have noticed a piece of used Copper braid attached to the middle wire. Well, since this wire goes to the Collector of the transistor, and since most non-tabbed BJTs are designed to cool through the Collector pin, I thought why not add a bit of extra cooling there as well. (Moreover, I wasn’t sure if the case mold of the TO-92 transistor would provide good enough heat transfer to the heatsink alone.)
