How does this PSU look?
  • myaccount
    • Sep 2017
    • 7
    I just got a used Sparkle FSP400-60GN. I opened it up and one cap is bulging/leaking. How does the build quality look - will it be a good PSU once the caps are replaced? And would those 2 giant black Teapo LXK 200V 1000μF caps need to be replaced too?
    https://imgur.com/kXbNrIT
    https://imgur.com/QJXD9UI
    https://imgur.com/opwSvDP
    https://imgur.com/3eKCyr4
    https://imgur.com/VrrtEOY
    https://imgur.com/UGMMMA9
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: How does this PSU look?
    When it comes to heatsinks, heavy metal is good. Those look good. The 2SC4110 switch transistors are nice and beefy, too.
    PeteS in CA
      master hoarder
      • May 2008
      • 12175
      Looks pretty good to me.
      For a moment, I thought this PSU was the same as the one in this thread:
      https://www.badcaps.net/forum/showthread.php?t=37356
      ^ but that one is a FSP400-60GLN, which appears to be a completely different platform with Active PFC. Yours has the oldschool voltage-doubler circuit (the two 200V caps on the primary), which IMO is a lot more dependable.
      On that note... No, you do not need to replace the Teapo LXK, 200V, 1000μF caps, as they shouldn't give you any issues because the PSU not have APFC. Also, at 1000 uF, that's more than enough for a 400 Watt unit. So your hold-up time should be pretty good.
      Just replace the output caps as well as some of the small e-caps too. I'm not faimilar with this model, so I can't tell you if the 5VSB circuit uses a 2-transistor design or not (and whether it has a critical cap or not), but if it does, you might need to replace the small caps for the 5VSB circuit as well. Other than that, it should be a solid PSU.
      • myaccount
        • Sep 2017
        • 7
        Thanks for the replies! Now I just need to find someone who can do this recapping.
          master hoarder
          • May 2008
          • 12175
          From what I know, Topcat (this site's admin and owner) still does recapping jobs, though I think it is mostly motherboards. Not sure if he does PSUs for customers (I think he does). I suppose it doesn't hurt to ask, of course.
          Alternatively, I could do it too (if you like), since I live in the Northern VA area... though that may not be that close, depending on where you live in the DC area. And I am also not an official repair shop or business - I do repairs mostly for myself, friends, and relatives. So if you are looking for an official repair place, I probably don't count. But I've done my fair share of PSUs.
          Anyways, feel free to send me a PM if you want to go the local route.
          • iMic
            IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
            by iMic
            Hi folks,
            I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
            The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
            11-29-2023, 06:44 AM
          • bauto601
            KDM 480W PSU upgrade succes! (opinions?)
            by bauto601
            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
            A "nice" YoungYear unit? - Badcaps
            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
            12-26-2023, 03:05 PM
          • Perry Babin
            samwha capacitors 10uf 200v/250v
            by Perry Babin
            The attached capacitors are used in the output filters of class D amplifiers and hold up well but when they fail, replacements are difficult to find. I've tried the various options on eBay and crossover caps and none survived. Mouser, Digi-key... don't stock many bi-polar electrolytic caps. The only thing that I found survived (never a failure) was the Mouser E2106 (part number 667-ECQ-E2106JF) and the same from Digi-key. They look different but survive. Does anyone know a readily available drop-in replacement electrolytic? The dimensions are approximately 16mm x 25mm....
            04-03-2024, 05:46 AM
            by momaka
            03-15-2023, 10:17 PM
          • socketa
            Hipro D2537F3H - Teapo output capacitor replacemnt
            by socketa
            Thought that it would be worth rescuing this one, but it's got one bulged Teapo that is in front of the big coil.
            Would it be perfectly OK to replace this 4700uf SC (which currently measures 600uf and 1.2ohm ESR) 5V output cap with XYJ 3300uf? More specifically, was the original 4700uf Teapo cap overkill?
            i also (inline) tested the 3300uf SC (which is parallel with a 2200uf SC cap, that is right next to it) on the 12V rail, and get a measurement of 5500uf and around 0.1 ohms ESR - So those caps look like they are still healthy?
            11-15-2019, 01:43 PM
