Multimedia projector, blown psu
  • madan1
    • Nov 2016
    • 726
    • Bulgaria
    Hi everyone.
    This is PSU from a NEC projector.
    A spring got loose and shorted to ground under q201.
    Blown parts found so far:
    top side
    fuse ( t5ah/250vac )
    r115
    q201
    r214 ( no ohm readings )
    d301 ( passing current in both directions )
    d302 ( passing current in both directions )
    bottom side
    r208 ( no ohm readings )
    r207 ( no ohm readings )
    If I change the above parts will this psu work fine or there are other components which might have blown?
    Also, can anyone help with the specs of r208 and r207?
    I found a service menu, but there are no schematics for the psu there .
  • R_J
    • 9631
    Re: Multimedia projector, blown psu
    Have you tried to get a used one? search for ZSNE834I might be cheaper to replace than repair.
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      The way i see it , R208 is 180 Ohms and R207 is a fuse bridge 000..
      It's not bad to check all the SM resistances for outranged values .
      • madan1
        • Nov 2016
        • 726
        • Bulgaria
        There are few second hand ones, but I wouldn't call them "cheap". I do not know how many hours are on the lamp, so I prefer to keep the repair costs as low as possible.
        Yeah, I also thought so.
        The fat path from the burnt resistor goes straight to IC202. Unfortunately the label has faded and it reads something like 2A09d23 which is not recognized as IC . IC101 is a switch/booster and with a totally different label.
        • jiroy
          • Jun 2016
          • 2416
          • Lebanon
          Since the label is missing , no schema , the only option now is to bet on a blown bridge fuse R207 while IC202 remained protected after it . You can put a temporary 1 or 2A Fuse for more safety testing .
            R207 is part of the Gate drive circuit which is driven by SMPS IC202 which is probably bad for sure now.
            Can you read all the printings on top of that IC202 and tell us what they are?
            • madan1
              • Nov 2016
              • 726
              • Bulgaria
              Here are the best images I can take of that IC.
              line 1 - *A*9D23
              line 2 - 5528
              I'm almost 100% sure that the first character is "2", but the third one is a mystery
              • petehall347
                • Jan 2015
                • 4451
                • United Kingdom
                5528 ..
                http://www.datasheet-pdf.com/PDF/FA5...lectric-729037
                • madan1
                  • Nov 2016
                  • 726
                  • Bulgaria
                  THANK YOU!
                  I didn't even think about searching for the 4 digits.. I thought this was a production date or something
                  The IC seems to be fine.. no shorted pins, but the diode d209 between the ground and the output ( pins 4 and 5 ) was shorted ( current in both directions ).
                  Also, in the IC documentation, page 16, the connection to the mosfet is straight, so the guess for "000" r207 was correct ( points go to jiroy ).
                  So the things are starting to get clear - the power surge got almost everything in that rail
                  • R_J
                    • 9631
                    Maybe have a look at page 33 two resistors in series one is 100 ohm one is 10 ohm
                    • madan1
                      • Nov 2016
                      • 726
                      • Bulgaria
                      No "1" for sure.
                      By the way, in the sample, for transistor is used 2sk3687.
                      Will it be ok to use 3687 ( which seems to be more easily obtainable ) instead of 2sk3564?
                        For that Gate drive resistor to burn up like that, large amount of current has to flow through the resistor and through pin 5 output pin of that IC, so more likely the circuit om the output of the IC has gone open circuit. I WOULD replace that IC for sure.
                          Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
                          This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                          09-06-2024, 06:11 AM
                        • cmlewis89
                          LG 47LB5DF blown power supply board
                          by cmlewis89
                          Hi folks,
                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                          09-03-2024, 07:50 PM
                        • drscoot
                          HP X360 convertible battery blown fuse error, not charging
                          by drscoot
                          HP Modelnumber: 14-dh0061nb​
                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                          All these 3 batteries are charging...
                          12-15-2023, 05:54 AM
                        • jamespeterh
                          APC SMART SUA 2200 XL 640-0800G REV 7 cannot detect any load placed
                          by jamespeterh
                          Hi, all
                          I've posted a similar Q&A on alternative site but this site seems to be more focused in saving UPS.
                          The system is a SUA 2200XL Rev 7 230V 640-0800G Rev 7
                          I have UPS that has a strange fault, it does not show or indicate any load on the system, via display or internally coms, LED test front panel works all light up.
                          has anyone else seen a fault like this , operates but no load recorded, or just blown one of the important non replacable IC's
                          1. internal monitoring via cable direct into the CPU that no load is present even...
                          06-21-2025, 06:19 PM
                        • w00pz
                          Identify blown component on HP ENVY X360 13-arxxxxx, Motherboard G1 13 AMD X360 18740-1 448.0GA03.0011
                          by w00pz
                          I have blown a component on HP Envy x360 with motherboard G1 13 AMD X360 18740-1 448.0GA03.0011.
                          Unfortunately there are no schematics available and the component was so blown the marking weren't readable.
                          I have marked it with a red circle in the attached photos - sorry for the mediocre quality I was too much in a rush.
                          Hope someone will be able to identify the component.
                          Many thanks for your help!
                          Edit: High-res picture added on a normal board (not mine)...
                          11-08-2025, 02:48 PM
