Astec AA16990 PSU failure
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Astec AA16990 PSU failure
    Originally posted by powermax
    There is just only ONE electrolytic cap on this board - 10uF, 25V, Nichicon. Replace?
    Worth trying anyways. Save the old cap, though, in case it is still good. I see a few more small caps, though - one near that daughterboard on the secondary side and two more on the primary side.
    Hmm, it looks like it will be difficult to get a new "AS431". Ok to replace it with a "TL431"?
    Yup.
    TL431, KA431, and AS431 are all the same thing, just made by different manufacturers. It's the "431" in the name that designates it's an adjustable shunt.
    Same goes for your AS3842 PWM controller - it's an equivalent to a UC3842.
    Another point I forgot to mention: are there any potentiometers or variable resistors anywhere in the PSU? Sometimes, those are used for fine-tuning output voltage regulation. Pots are a lot more susceptible to damage from moisture and dust, so if your PSU has one, check it.
      • 31029
      no problem, everybody makes the 431 - but sticks different letters on them.
      beaten to the post-button
      • powermax
        • May 2017
        • 49
        I didn't see anything having a screw in this PSU.
        • powermax
          • May 2017
          • 49
          I just searched the web for both "TL431" and "KA431". Digikey and Moser offer this component in different packages. There are two TO-92 ICs having four-letters-suffix like "KA431AZTA" or "KA431LZTA". They look similar but I'm afraid there is some difference. I don't want to destroy my PSU by installing an incompatible IC. I'm completely lost...
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            "TL431" is just TI's version of a very old (1970s design) part created by Signetics. Lots of companies make equivalents (Samsung's was a KA431, IIRC). They should be interchangeable.
            The LM2903 is a dual comparator, while the LM339 is a quad comparator. The performance of the individual comparator sections of the two parts should be more or less identical. A triac, once fired, can conduct in either direction, making it suitable for AC (unlike an SCR, which conducts in one direction only). And once a triac has fired, it doesn't turn off until current is interrupted (basically, until the power supply is turned off).
            PeteS in CA
            • PeteS in CA
              • Aug 2005
              • 3581
              #26
              The "KA431AZTA" and "KA431LZTA" are compatible parts, now made by On Semiconductor (originally Samsung, then Fairchild bought the rights to the part from Samsung, and then Fairchild was bought by On Semi). The "AZTA" means 1% tolerance; the "LZTA" means .5% tolerance.
              PeteS in CA
              • powermax
                • May 2017
                • 49
                I got an old Nippon Chemicon cap, 10uF, 25V, KMA Series (see attached image). Okay to replace it with this one?
                http://www.mouser.de/ProductDetail/U...XjttuxTw%3d%3d
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  #28
                  It probably would... but what brand and series was the original cap?
                  The KMA you pointed to seems like a general purpose cap, and only has a rated endurance of 1000 hours.
                  I suggest going with 10 uF, 50V Chemicon KY, as they are usually readily available.
                  • powermax
                    • May 2017
                    • 49
                    Like I said in my previous post, it's a Nippon Chemicon, "KMA" cap.
                    Okay, there are two different ones:
                    1: http://www.mouser.de/ProductDetail/U...aeVizgO7F8s%3d
                    2: http://www.mouser.de/ProductDetail/U...167eVm9Bdhc%3d
                    The 2nd one has the "Life" of 5000 hours while the 1st one has no such indication. Which one would you recommend?
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      #30
                      Ah okay. So they had a general purpose 105°C-rated cap in there. Not a bad idea to change it then.
                      They are the same cap. Only difference is how they are packed. The first one comes in "bulk" - i.e. individual caps in a bag. The second one is for caps to come in a paper "reel" - this is used where a machine automatically can take the cap from the reel and place it on the board... i.e. for production/industrial use.
                      So you can go with whichever one you prefer. I typically go with whatever is cheaper.
                      • powermax
                        • May 2017
                        • 49
                        You're right! I've found four "KMA" caps in this PSU in total:
                        C207 (on the daughter board) - 10uF, 25V
                        C11 (near the daughter board) - 47uF, 25V
                        C46 (on the primary side) - 100uF, 10V
                        C30 (near the 12V output, see my schematic) - 10uF, 35V
                        I'm going to replace them all to eliminate this source of problems. C207, C46 and C30 can be easily replaced with the appropriate 50VDC, "KY" caps as you said because their diameters match and the length is not important.
                        In the case of C11, the "KY" equivalent is unfortunately too long (11mm vs 7mm). Is there another replacement possibility for this one?
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          #32
                          KZE series are sometimes smaller for the equivalent capacitance. But all I could find for KZE was a 56 uF, 25V for 7 mm height. 56 uF is just a step-up from 47 uF. And typically, a step-up in capacitance very rarely causes issues. So you may be able to use it if nothing else is possible. Here is the link for the 56 uF KZE with 7 mm height:
                          http://www.mouser.com/ProductDetail/...EbjMs2LB624%3d
                          Mouser part #: 661-EKZE250ELL560MF0
                          That said, I still suggest to go with a 47 uF cap, if possible.
                          Why is the height of C11 a problem?
                          I see that C11 is next to the daughterboard. If there are components above it, you can just tilt the new (bigger) cap a little bit to avoid that. So that way, an 11 mm cap should fit no problem.
                          • powermax
                            • May 2017
                            • 49
                            I replaced four small caps (C46, C11, C207, C30) and "AS431B" with "TL431AI".
                            Good news: the fan spins, nothing has exploded so far.
                            Bad news: the rails are still low (+5Vrail = 4.34V, +12Vrail = +7.20V, -12V= -4.4V). The voltages fluctuate quite much.
                            I'm testing the PSU without load. I've read somewhere that these ol' PSUs don't operate correctly without a proper load. Is it true?
                            • powermax
                              • May 2017
                              • 49
                              When I disconnect the fan, the -12V rail shows "-11,4V". With the fan connected, it has only -4,4V...
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                #35
                                Have you checked the batteries in your meter?
                                Because I would not expect the computer to work with voltages so much out of whack...
                                When I wrote the above I did so believing you where measuring these voltages with the computer connected as a load.
                                If you are saying you have done all this testing with no load at all then yea, that explains things.
                                The PSU needs a load to get the voltages stable, this is true for most cheap/older power supplies.
                                Some "solve" this by having a "minimum load" resistor for each rail.
                                But by "solve" that is a pretty crappy solution.
                                Because it's only really needed when you don't have a load.
                                So in effect it just produces allot of heat inside the powersupply making the caps fail much sooner than they would have otherwise.
                                Now please don't try to power your computer with the PSU just because I have said this.
                                You need to verify that the voltages actually are stable.
                                So try to find some large resistors to test with.
                                Lamps from a car can also be used but be careful because the inrush current is extreme and could actually damage the PSU.
                                • powermax
                                  • May 2017
                                  • 49
                                  Yes, such a "testing" circuitry built using incandescent bulbs has been already mentioned several times in this forum. Unfortunately, I couldn't find anything concrete.
                                  Do you have any tips or helpful tricks on how to build such a testing circuit for my PSU?
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    #37
                                    No that's only when repairing a PSU (The light bulb, wired in series with the PSU will light up only if the PSU is shorted, thus preventing whatever is shorted from exploding)
                                    Just put some resistors as load directly on the output cables where the mainboard would normally go...
                                    • powermax
                                      • May 2017
                                      • 49
                                      Ok, thanks! BTW, This post does explain in details how the mentioned bulb test works.
                                      Okay, is it correct that I'd need to attach a 1 Ohms/25W resistor to load the 5V with 5A and a 6 Ohms/24W resistor to load the 12V rails with 2A?
                                      • PeteS in CA
                                        • Aug 2005
                                        • 3581
                                        #39
                                        Your calculations are correct, but 25W resistors at 100% rated power would get extremely hot. 50W resistors - panel mount types mounted on a heatsink or tubular (this style) - would be a better choice.
                                        Or maybe:
                                        * Two 2 ohm, 25W resistors in parallel for the 5V;
                                        * Two 12 ohm, 25W resistors in parallel for the 12V.
                                        PeteS in CA
                                        • powermax
                                          • May 2017
                                          • 49
                                          Yes, I learned to pick at least the doubled wattage because I'm not going to "fry an egg" with the load resistor
                                          Or maybe:
                                          Good advice, thanks a lot! The question is that the 5V rail of my Astec PSU has the max. power of 11.6A. Should I test this PSU with a load close to its maximum, say 10A? If yes, what combination can I use to meet the required resistance of 0.45 ohm, 55W?
                                          • nick3092
                                            Mid/late 80's Nichicon Yellow Caps
                                            by nick3092
                                            I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                            08-28-2022, 03:56 PM
                                          • Eh546
                                            Polk PSW125 capacitors choices for a beginner.
                                            by Eh546
                                            I was looking to repair my Polk PSW125 subwoofer plate amplifier, i've checked around the web and it seems to be a capacitors problem.
                                            Took apart the amp, and made a visual inspection, everything's seems fine, fuse ect no burn marks, but i noticed 3 caps that were a little bit bulged. One 400v 150uf, one 50v 47uf, and two 63v 47uf.
                                            I noted each caps voltages and uf anyways, and made a list on digikey. Some recommended Nichicon and Panasonics ones (FR and FM) serie. So I tried to stay with the Panasonics FM-A serie.
                                            I would like to know if the caps i selected...
                                            12-21-2023, 07:28 PM
                                          • DrewPhillips
                                            Capacitor Diarrhea - Nichicon PL Series
                                            by DrewPhillips
                                            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                            03-02-2025, 10:18 PM
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            The TV does not turn on, the standby indicator is on. All voltages are present.
                                            Emms is dead. Not readable, not detected.
                                            Replaced emmc.
                                            But with another dump there is no launch
                                            Terminal log
                                            UART
                                            AC_ON
                                            RPMB key is not yet programmed
                                            HASH1_VERSION=0x00000000 64bit
                                            E-B
                                            FDE enabled
                                            layout pattern onebin by SAR7,0...
                                            06-01-2025, 02:11 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
