Astec AA16990 PSU failure
  • PeteS in CA
    • Aug 2005
    • 3578
    • USA, Unsure of Planet
    #41
    Re: Astec AA16990 PSU failure
    I'm not sure what your purposes are at this point. If you want to see if it can deliver full rated power, be sure to notice that if all 3 outputs are at maximum current the output power will be 94W, well above the rated 86W.
    With that noted, a 10A load on the 5V would, nominally, be 50W and the load resistance would be .5 ohm. Two 1 ohm, 50W resistors in parallel would be an easy way to do that.
    PeteS in CA
    • powermax
      • May 2017
      • 49
      Oh yes, you're right! That shows that I can't fully trust those (bogus) values on the PSU's case.
      Thank you very much, Sir! I'll do the tests and report the results.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        #43
        You don't need to load the rails down to 100%
        A 10% load on each rail should be enough to tell if the voltages become stable then or not.
        • PeteS in CA
          • Aug 2005
          • 3578
          #44
          They aren't bogus values. It just means that if you use the full load current of the +12V, you have to use less than full load on the +5V. I would expect this to be the case with any PSU model from a good power supply vendor (e.g. Delta, Lite On). Astec was a top power supply vendor (Are they sold under the Emerson name now? Emerson has owned them for decades, so it's probably just a name change.).
          PeteS in CA
            master hoarder
            • May 2008
            • 12164
            #45
            Exactly!
            This being an old PSU, though, I would recommend loading the 5V rail more than anything else. 2 to 3 Amps would be very good to keep the PSU stable. As for the 12V rail - an old hard drive should do (just take one that you don't mind sacrificing *if* something goes bad... which it probably won't, since this is an Astec PSU).
            Lamps from a car can also be used but be careful because the inrush current is extreme and could actually damage the PSU.
            I have not damaged a PSU by doing that yet. Then again, I've done that only with 2-3 bulbs max attached to the whole PSU just as a minimum load. If you try to load down a PSU to the maximum load with 12V auto bulbs... yeah, you're going to have a problem with inrush.
            Yes, such a "testing" circuitry built using incandescent bulbs has been already mentioned several times in this forum. Unfortunately, I couldn't find anything concrete.
            Well, there's two, actually.
            One is the incandescent light bulb primary (line-side) series test, which is used when you rebuild a PSU that had a blown fuse and want to make sure it doesn't blow again.
            The other test involving incandescent bulbs is for testing the output (as mentioned above already). For this one, you use 12V car bulbs or the 12V bulbs found in some home track lightning (Ikea has a few of these). A bulb in the range of 20-40 Watts should give 1.5-3 Amps of load on the 12V rail and about 1-2 Amps on the 5V rail.
            • powermax
              • May 2017
              • 49
              I've built a "load device" that consist of two 2 Ohms, 25W Ohmite tubular resistors connected in parallel and two 12 Ohms, 25W Vishay wirewound resistors in parallel mounted on an improvised heatsink. This device loads the 5V rail with 5A and the 12V rail - with 2A. The -12V rail remains unloaded.
              Now I get the following voltages:
              +5V rail ----> +4.98V
              +12V rail ---> +11.86V
              -12V rail ----> -12.08V
              Everything seems to be okay now. The voltages are stable too, although the test lasted only about 2 Min. because I didn't want to "fry an egg" with my load device (PeteS in CA was right - the resistors will get pretty warm very quickly and the fan spins very fast).
              Thank you all for your precious technical help! I think it's the time to test the PSU with the computer, isn't?
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #47
                Absolutely!
                And well done on the load test
                • PeteS in CA
                  • Aug 2005
                  • 3578
                  #48
                  I'm going to venture a guess that the -12V output is regulated by a 7912 or LM320T-12, so being unloaded is no big deal. I think the 3-T might be on the large heatsink near the output wires.
                  Looks like you got it fixed. In real use, I doubt that computer loads the power supply much higher than 75%.
                  PeteS in CA
                  • nick3092
                    Mid/late 80's Nichicon Yellow Caps
                    by nick3092
                    I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                    08-28-2022, 03:56 PM
                  • Eh546
                    Polk PSW125 capacitors choices for a beginner.
                    by Eh546
                    I was looking to repair my Polk PSW125 subwoofer plate amplifier, i've checked around the web and it seems to be a capacitors problem.
                    Took apart the amp, and made a visual inspection, everything's seems fine, fuse ect no burn marks, but i noticed 3 caps that were a little bit bulged. One 400v 150uf, one 50v 47uf, and two 63v 47uf.
                    I noted each caps voltages and uf anyways, and made a list on digikey. Some recommended Nichicon and Panasonics ones (FR and FM) serie. So I tried to stay with the Panasonics FM-A serie.
                    I would like to know if the caps i selected...
                    12-21-2023, 07:28 PM
                  • DrewPhillips
                    Capacitor Diarrhea - Nichicon PL Series
                    by DrewPhillips
                    Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                    The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                    03-02-2025, 10:18 PM
                  • Sus256
                    HISENSE 65E7KQ PRO - no boot
                    by Sus256
                    Hi all!
                    HISENSE 65E7KQ PRO
                    RSAG7.820.13512 - chassis
                    MT9618BAATAB - cpu
                    RSAG7.820.12059 - power
                    HD650Y3U77 - panel
                    KLM8G1GETF - emmc
                    Replaced emmc.
                    Terminal log
                    UART
                    AC_ON
                    E-B
                    FDE enabled
                    06-01-2025, 02:11 AM
                  • chth96
                    Is there datasheet for nichicon LXJ series?
                    by chth96
                    I want to calculate capacitor ESR referring to below guide.
                    https://forum.digikey.com/t/calculat...-from-tan/2633
                    I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                    I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                    Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                    11-20-2022, 08:11 AM
