how NOT to do a recap
Re: how NOT to do a recap
Reminds me of my old 350W CWT I had when I first bought it. (second hand) I found a dangling around 2200uF 16v UCC KY cap that was connected with wires.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Reminds me of this guy:
https://linustechtips.com/main/topic...caps-on-a-psu/
Using GP caps instead of low impedance. And fan controlled by the Motherboard...
Is there anything more you can do wrong?Comment
Good posts guys, I've been using Antec PSU's for PC Replacments for the last 4-5 years, only ever had one come back under warrenty, whats your take on Antec branded PSU's, They are a very solid build, and were recommended to me by another Technician, I've never had to do a recap so i dont even know if they use quality Caps in the build or not, must check it out when i get time, tanx guysComment
Recent ones sadly seem to be mostly Seasonic. With full Japanese caps. In General all High Current ones and the Edge and True Power Classics come with 'All japanese caps', though Edge and TPC are just seasonic G-Series. And really interesting are only the (expansive) High Current Pro Platinum ones -> made by Delta.
Don't know much about the lower end ones though. Some are made by Delta and use non japanese caps...Comment
Heard of Dunning Kruger?
You need to be competent to know if the other one is competent.
If you are incompetent, you don't/can't know if the other is incompetent.
Though sometimes you may want/need to use your brain to see if it is sensible what's done...
Sometimes you can see that the one is incompetent -> PCB of PSU looks clean...Comment
i watched a "tech guy" on utube the other day spend over a min pressing F2 on a keyboard only to declair that the motherboard could be faulty because he couldnt enter the bios.
it clearly said at the bottom of his monitor "press DEL to enter"
what a dickhead!Comment
The last ones I can confirm being CWT-based, are the 2005s.
Mostly 2000-2005.
Fuhjyyu caps appear to be the worst in 2003, 2004 and 2005...
I think my 2005 Antec SmartPower 2.0 500W got a bulging Fuhjyyu cap on the +5 VSB rail, because it had a lower-pitched squeal when the PC was off and the house was quiet... (Back in 2011, right before I stopped using it.)Last edited by RJARRRPCGP; 05-23-2017, 06:25 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
by momakaHere’s another motherboard that needed a full recap: an ASUS P5GC-MX.
This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
So here is what the motherboard looked like with its original caps:
CPU VRM area up close…... -
by momakaI've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
This one was actually suggested to me by ChaosLegionnaire.... -
by laskr1999Hello!
I have got a DFI Lanparty NF3 250GB motherboard, that have all of the capacitors failed, board still working.
I have read, that I need to match ESR, Capacitance, Voltage to have a quality recap, but with ESR im in a problem. 0.012 ohm is what i see on the vrm caps specs, but lowest I could find is 0.018 and up, usually 0.04. Can someone help me find good replacements?
I'm located in EU, and I have found a guy here on the forums who listed the caps, so here are they:
- 20 x Nichicon 1000uF 6.3v HM 105C
- 5 x Chemi-con KZG 1000uF 10V
- 1 x Chemi-con KZG...-
Channel: General Capacitor Questions & Issues
11-25-2025, 03:27 PM -
Hi guys,
I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
Looking for someone experienced with older PC boards who uses...07-29-2025, 11:53 PM -
by FoetussHi all
Hope this is in the correct place.
I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
Could use some double checking to see if I'm not doing something stupid
Pictures of the boards are attached.
What I will be replacing with what : (planned)
Soltek Golden ::
4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...2 Photos-
- Loading...
