Re: some dead capacitors in a 9v 2.6A power supply
I know it's been a year since i made this but i finally got around to fixing this stupid thing and it works. (even when it's under full load)
Photo of the new caps....
I removed as much of the cheap gule as i could and i'm currently waiting for some silicone glue to cure.
The silicone glue is made for electronics and i used it on a different power supply and it did not do any harm.
Originally posted by ruky con View PostI'm not sure how this thread is still alive.
I already have an order ready to be placed.
This thread is clinging onto life by a thread.
One idea i had was to take a bunch of chinese capacitors and put them on a frying pan and watch them pop like popcorn.
Originally posted by redwire View PostSome cheap chinese power supplies are doomed, as the caps are simply too small - physically and electrically, to last. It has little to do with the make/brand of the cap, more to do with the ripple/ESR heating.
I would look at the ripple current spec. - here it's quite high for most caps, especially at 2.6A output split over 2x1,000uF+220uF low-profile parts.
Sometimes I add an extra bulk capacitance on the output when I need long life.
Panasonic EEU-FR1C102 1,000uF 16V D=10mm H=16mm 1.79A ripple 8,000hrs
P.S. I prefer a "POPcorn" capacitor brand over "BAcon" brand. If you smell popcorn, it's over
One idea i had was to take a bunch of chinese capacitors and put them on a frying pan and watch them pop like popcorn.Last edited by RukyCon; 03-15-2017, 01:00 PM.
Originally posted by eccerr0r View PostNeed a capacitor company whose founder is "BA" and add some breakfast meat compounds into the electrolyte. Then when the cheap cap explodes, at least it will smell tasty.
Then label their caps "BAcon".
Originally posted by ruky con View PostOk i thought you were trolling me or something.
I get the joke.
42 The answer to life the universe and everything.
Originally posted by jazzie366 View PostFuck, I meant Suncon, damnit I was so tired when I made that.
Originally posted by ruky con View PostSuncap is the brand that failed in my power supply.
And i don't think suncap made capacitors for sanyo but i do think suncon did.
And the only link on your post is for the nichicon SMD capacitors [which i don't think they are real nichicon capacitors.]
Originally posted by jazzie366 View PostHey, I found some caps that'll work in your power supply that you'll like.
Suncap ME-CA series, this is their small, low impedance series. They're a japanese brand, and they make caps for Sanyo. They have the exact same vent on them as well, and the sleeving for their green and gold ones have the same font and everything as Sanyo, just a name change.
I'd recommend these because they're a good brand and the series I linked you makes the 16v 1000uF cap in the case size you need.
However, if you want to mod this supply a little bit or are just living on the edge, put some of these in there: http://www.ebay.com/itm/10-PCS-Nichi...cAAOSwAuZX3xff
Sanyo does not exist for many years so I wonder how anyone can make anything for them.
How exactly do you put SMD cap to THT?
Originally posted by ruky con View PostThe cap i have has a ESR of 0.28...
And i still have some dead LED lamps that failed less then 1 month after installation.
And that's why i don't like LED lamps.
Originally posted by jazzie366 View PostThe cap you have from Pchicon is rated for 12000 (not a mistake) hours... my ass.
They are rated high ripple, low ESR, long life.
I'd love to see it go into something, they're meant for LED power supplies, maybe I'll order one of those cheapys from eBay that I know has them in it, and see how long it lasts.
Originally posted by ruky con View PostI did not notice that the vents were all off-center.
It shows you how cheap they are.
Originally posted by ruky con View PostHere you go...
Note: The brands are 100% random so i can not guarantee you'll get the same brands that i got.
http://www.ebay.com/itm/210Pcs-25-Va...3D172377962894
Originally posted by jazzie366 View PostCould you tell me what ebay assortment sold you this? I'd like to get my hands on a few of the odd brands like this.
