Really Corsair? A 250$ PSU with bad solder joints?
  • jazzie366
    • May 2016
    • 304
    Hey guys, this is kinda weird for corsair, especially for this high class of a PSU. I have a Corsair HX750, which if I remember correctly, I paid 250$ for, Newegg has them listed for 260. It's a really fine PSU, pics below show the amazing build of this thing, except I didn't pull the board (yet).
    This one is about 2-3 years old, used to run a BTC miner, now runs my gaming pc. Well, as of a few weeks ago, my USB ports were getting funky, then out of nowhere they'd shut off and unless I unplugged everything from the mobo, I didn't get them back. I could leave small things like a mouse or keybo, but anything high draw like a network adapter, external hard drive etc, wouldn't let them come back. So I ran some voltage testing annnnnnnnd:
    4.37V under small load.
    Obvious problem there.
    Well, I opened the case, all voltage regulators seemed fine, nothing obviously wrong at first glance so I tore it apart and nothing. Then I went to the PSU after still not seeing anything wrong, plus this was an Asus board which I religiously use because I never have problems.
    So I get the PSU open and hey! Looking good with all those japanese caps, NCC and Panny's all around, nice! No bad caps here. Except... I started wiggling things around to check for loose components, and I'd have to say 2/6 caps were freely moving, and could be pulled up on to move around in the solder joint, as the joints had gone cold. More wiggling of components also yielded a slightly loose heatsink that could move a good 3-5mm. There's a couple small boards near the output, those were pretty sturdy and fine.
    However, if you look down by where the 12v wires connect, there's an obvious lack of solder on the traces as they're not even filled.
    I have to say I'm disappointed with Corsair, in another threat I talked about how I have an RM1000, a much newer PSU, maybe 1 year and a half old, it's filled with Taicon and CapXon caps, and that's a 284$ power supply on Newegg.
    Is it just me, or is corsair's quality starting to go down the toilet?
    Popcorn.
  • mockingbird
    • Dec 2008
    • 5484
    Re: Really Corsair? A 250$ PSU with bad solder joints?
    It's not Corsair's fault, per se. They have to use ROHS solder, and it really is touch and go for these kinds of applications.
    • jazzie366
      • May 2016
      • 304
      Even after all these years, you'd think they'd work the bugs out of this though.
      Also, it looks like a lack of solder rather than the solder's fault, as the PSU isn't that old.
      Popcorn.
      • cpt.charlie
        • Sep 2013
        • 270
        • Spain
        Just a bad quallity control.
        • dmill89
          • Dec 2011
          • 2534
          No surprise, it is a CWT build and they aren't exactly known for "quality control".
          Starting to???? Corsair's PSUs have been mediocre at best for the last several years. Not as terrible as the off-brand junk (even the entry level units), but in most cases no better than dozens of other units at the same price point. Corsair has also been relying heavily on CWT for the lest few years (early Corsair PSUs were primarily Seasonic builds, but that changed years ago) which is known for spotty quality control, and garbage caps on cheaper (and even some not so cheap) PSUs.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Corsairs has been overhyped mediocre overpriced stuff for years. What exactly is the surprise here? The old ones were Seasonic but ever since they aren't, they're not really good. I've been favoring some of the newer Seasonic-built XFX power supplies which are a good value.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Sadly, CWT got a bad rep, because of bulging and leaking Fuhjyyu caps in their mid-2000s PSUs...
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • dmill89
                • Dec 2011
                • 2534
                Yes, though they have other quality control issues as well (I've seen many reviews indicating poor soldering, loose screws, etc.), and they still use junk caps in pretty much all of their entry level units (though so do many other manufactures), and even some of the higher end ones as well.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  The only other problem that I had with CWT, was that brown glue!
                  Arc A770 16 GB
                  • Stefan Payne
                    • 1267
                    It costs more. So not all companys do it.
                    • Bungz
                      • May 2013
                      • 133
                      CWT don't like to tighten screws either.
                      Nice unit, reflow the connections and tighten up the screws see how she goes.
                      • jm1234
                        Solder joints on heat sinks matter?
                        by jm1234
                        solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
                        I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
                        04-28-2024, 04:38 AM
                      • abajor
                        x1 Carbon Gen 9 HYG60\HX4B0 NM-D341 Rev: 1.0, CSD87501L Failed solder Joints.
                        by abajor
                        I had a x1 Carbon Gen 9 come in with a no charge and no USB C power up problem (the machine would turn on with a new battery until it lost charge).
                        I noticed lifting the protective black membrane near the USB jacks that two little BGA chips were stuck to the adhesive and had fully released from the mother board, one of them looking fully scorched. Q261 and Q263 power MOSFETS.
                        I found the schematic and diagram for the board here.
                        https://www.badcaps.net/forum/troubl...e-devices/sche...
                        07-20-2024, 04:46 PM
                      • corrize
                        Best way to solder LVDS connector for beginner (and qfn) ?
                        by corrize
                        Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                        I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                        I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                        See the test :
                        https://youtu.be/bNAzC-EvqHs?t=1767
                        With hot air from bellow the board, that's...
                        03-09-2023, 02:57 AM
                      • myth77
                        UV solder mask - high temp resistent, recomendation?
                        by myth77
                        Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                        Is there any solder mask...
                        03-28-2022, 04:04 AM
                      • petemanuk
                        BGA solder balls not connecting - help pls
                        by petemanuk
                        So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                        I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                        I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                        11-16-2022, 05:21 AM
