JVC THS9 Home Cinema System SMPS No outputs or standby power
    Re: JVC THS9 Home Cinema System SMPS No outputs or standby power
    i would change c914 unless you have a capacitance/esr tester too test it correctly
    I agree, that will be an easy thing to do.
    • Percyveer
      • Jan 2017
      • 47
      Will do.
      I have to hand a 22uf/25v or 47/16v will either of those do for testing purposes?
      • CapLeaker
        Leaking Member
        • 8196
        It has to be at least a 25V cap. I'd try the 22 or better a 47uF. 25V, 35v 50V doesn't matter. 50V 47uF are very common.
        • CapLeaker
          Leaking Member
          • 8196
          Originally posted by budm
          It may be the circuit inside the IC on VCC pin 4 is loading down the Voltage, when check the resistance with the Ohm meter on pin 4 and GND it may not be valid due to the meter does not put out high enough Voltage to cause the circuits inside the IC to conduct.
          One way to find out is to use isolated external power supply to feed the IC pin 4 VCC.
          O.k. so in this circuit, if we take out IC901, there should be then the 21V startup juice on cap c914 then, if the IC901 is at fault.
          • Percyveer
            • Jan 2017
            • 47
            I found a 47uf/25v and it is now soldered in.
            The voltage now across the cap is difficult to measure, as it is oscillating, but is somewhere between 12.5 and 13.8vdc.
            No change in any other voltages.
            • Percyveer
              • Jan 2017
              • 47
              Do I take this road now?
              • Percyveer
                • Jan 2017
                • 47
                Thank you all for assisting me thus far, it is greatly appreciated.
                Well I carried on and removed the STR G6651, and the voltage across the start up cap charged up to 76vdc, thought that a bit high so replaced the existing cap that appeared to be OK and the cap is now charging up to 37vdc.
                With the IC removed I have tested across all the pins to each other and there are no shorts. Is it defective?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #48
                  what voltage is the capacitor you replaced? at that voltage running through it supprised it did not explode.
                  • CapLeaker
                    Leaking Member
                    • 8196
                    O.k. so the voltage did rise when you took it out. Right now I'd be changing that IC901.
                    I can't see having 76V DC there. Vinceroger is right... something should went poof. What was c914 originally? The schematic doesn't show correctly.
                    • Percyveer
                      • Jan 2017
                      • 47
                      Vince: The cap used for testing purposes was 47uf 50v.
                      The spec of the original which is now back in is 39uf 25v.
                      • Percyveer
                        • Jan 2017
                        • 47
                        Hi Capleaker, it was 39uf 25v.
                        • Percyveer
                          • Jan 2017
                          • 47
                          To clarify the 76vdc was there with the 47uf 50v cap in there.
                          But the original 39uf 25v is still producing 37vdc, too much for its spec isn't it?
                          Or will it drop when the IC is replaced?
                          • CapLeaker
                            Leaking Member
                            • 8196
                            39uF is a very odd value, but that is what the schematic shows too... I thought that was a misprint. Put the original cap back in its place for now and change that IC. Because we need to know that the IC is working to hopefully fix the situation or troubleshoot it further.
                            Having too much voltage on the cap isn't good, but I am wondering "what" you actually measured. I expected the voltage to rise on the cap, when the IC is gone, but surely not a value of 76V.
                            Lets see if budm sees this.
                            • Percyveer
                              • Jan 2017
                              • 47
                              You may have skipped over what I wrote.
                              The original is back in and the voltage is now 37vdc.
                              When taking these voltage measurements the probes were kept on the cap pins until it had maxed out, probably took 5 secs to get there.
                              • Percyveer
                                • Jan 2017
                                • 47
                                Unable to obtain these Allegro STR G6651 in UK.
                                Can get from china, probably clones, can anyone confirm these are reliable.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #56
                                  theres one on ebay
                                  http://www.ebay.co.uk/itm/STRG6651-I...MAAOSw34FVCvqh
                                  but not sure what package type yours comes in
                                  • Percyveer
                                    • Jan 2017
                                    • 47
                                    Vince: Thank you for the link.
                                    Yes it is that package.
                                    They do not state that it is made by Sanken, I am awaiting a reply from them, it should be at that price, but I think it will turn out be an expensive clone, which if it is the case, I may as well take a gamble on aliexpress at 65p each.
                                    Percy
                                    • CapLeaker
                                      Leaking Member
                                      • 8196
                                      yeah, but the difference going from a 39uF to 47uF shouldn't be 37V vs 76V. It will ramp up and down all the time. Sure, the line isn't loaded now, I expected a rise in voltage, but not to 76V because you increased the startup cap by 8uF.
                                      Did this thing go just out one day, or was there a power surge of some kind?
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #59
                                        aliexpress are a good company been having a fair few parts etc from them but delivery time varies im on my 6th week for one part too arrive but saying that other stuffs been just over 3 weeks so cant complain i guess,
                                        • Percyveer
                                          • Jan 2017
                                          • 47
                                          It did not ramp up and down, just climbed to the max and stayed there.
                                          I can only report what happened, it would not help my cause to say any different.
                                          Just went out one day.
