What's the point of a 0Ω resistor?
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Was looking through some schematics and saw a 0Ω resistor. What is the point of having a resistor if it isn't even 1Ω?
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: What's the point of a 0Ω resistor?
    Can burn out if too much current/voltage is applied Ie S/C further downline so can act as a fuse. Vestel do this all the Tv with their Tv boards use 0ohms as fuses. But they can also act as links etc.
    • TechGeek
      Computer Geek
      • Jan 2015
      • 2254
      Oh Ok
      sigpic
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3264
        • Singapore
        they could have just called it a fusible resistor in the schematic? i believe they even have a circuit symbol for fusible resistors?
          • 31037
          they are often fitted because you can lift them to isolate parts of a circuit,
          or because they need to bridge over some other tracks, and old pick&place machines couldnt auto-insert jumpwires.
          but they could insert resistors.
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            never though of that ... always made me wonder but never studied it ... i thought them as fuses .. then again i see lots of resistors as fuses .especially if limiting current
              • 31037
              if you crush a 0-ohm resistor you will find that atleast 50% of them are actually a continuous copper wire or even a metal sleeve and not a carbon or metal-oxide device at all.
              i just murdered one for you.
              pic1 - as it was desoldered.
              pic2 removed the paint - looks like a plated metal body.
              pic3 - crushed it in a crimp tool - it's solid copper with tin plating!!!
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Probably because the pick & place automated assembly can't handle straight wires.
                • Stefan Payne
                  • 1267
                  There are various reasons, some are already mentioned.
                  But there's also another reason:
                  They are often used as a jumper nowadays. Like on AMDs Radeon RX480 reference Board, there are a couple of 0 Ohm Resistors used to adjust the distribution of power. Ie if the Power comes from the PCIe slot or the Power cable.
                  With this knowledge you can also modify some graphics cards to run either totally off the cable or the slot.
                  • TechGeek
                    Computer Geek
                    • Jan 2015
                    • 2254
                    Hmmm
                    sigpic
