what is the point of R1 resistor on ps4 slim ADP-160CR power supply?
  • gergely
    • Oct 2017
    • 25
    • Spain
    I am looking at the schematic and i dont understand why is it important to have a 0,1 Ohm resistor. Does it have to do something with the 2 mosfet (Q3 and Q4) in series? What if i just replace it with a wire? thanks
  • redwire
    • 3912
    Can you post a link to the schematic? Why do you think shorting out a resistor and it will work fine?
    The resistor has a purpose, it failed because the mosfets are shorted.
    • lotas
      • Jan 2016
      • 4919
      • Russia
      The current resistor also plays the role of a fuse, if the Mosfets burn out, then they take with them the SMD resistors, diodes, zener diode and PWM, definitely change the PWM (if you don’t replace it, the Mosfets will burn out instantly the first time you turn it on) and check everything else...
      • gergely
        • Oct 2017
        • 25
        • Spain
        thank you
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • gica69
          Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
          by gica69
          I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
          Resistor shows orange range silver gold and green lines.
          Thanks in adv...
          07-21-2025, 09:49 PM
        • Safrilhg
          Look for the resistor value in the BenQ G922HDAL monitor's power supply
          by Safrilhg
          Hello guys, I had a problem where I didn't know the value of the burnt SMD resistor in the power supply circuit of the BenQ G922HDAL monitor.
          In one of the parts, there is a burnt SMD resistor which leads to the LD7560GS IC as shown in the picture below.
          How to determine the appropriate SMD resistor value for this condition? Thank You...
          11-06-2023, 12:43 PM
          HP Slim Desktop S01-pD0117d Slim Desktop i3-8100 Specification for Upgrade or Repair
          This specification for the HP Slim Desktop S01-pD0117d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pD0117d boardview and Slim Desktop S01-pD0117d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-12-2024, 03:28 PM
