Coolmax unraveling
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Coolmax unraveling
    No, that's not a KME PSU. KME uses transformers that say "Ever-Power" on them. I wanna say this looks like an old low end CWT, but I'm not sure.
    • Drack
      Yup it's me
      • Nov 2016
      • 297
      • Venezuela
      Those Coolmax are kind of ok-ish units just overrated as always
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        • Romania
        I know. Probably some crappy YueLin platform (since they like adding the mH rating on some transformers) and the Coolmax is a Sun Pro.
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Hey that's a good point. Either way, the manufacturer should be ashamed. YueLin is capable of decent units.
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            • Romania
            Yeah,YueLin does some quite good 250W units. In fact,I have one (branded ALine - they were crazy enough to slap a LC-8500BTX model number on it,lmao) and it has 13009 (although in TO-220 package) switching transistors.
            So is Sun Pro though - if it weren't for the quite crappy PCB material,that Coolmax would have been good for ~350W.
            Strange though,I haven't seen any G-Alantic Enterprises PSU pop up in here. They're pretty honest with their ratings,and use beefy CWT ISO platforms (last one I had was rated for 350W and had a ERL-35 transformer. I know I transplanted the guts into a Delux ATX-450W PSU case and slapped a pink Xinruilian LP fan in there. (they're not that bad as people say)
            Main rig:
            Gigabyte B75M-D3H
            16GB DDR3-1600
            Delux MG760 case
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Lol they slapped an LC sticker on it... even in the small package, 13009s can be decent. G-Atlantic Enterprises? Cool, do you have any pictures? I have never seen one. Also, I have documented probably the best Sun Pro and ISO series PSUs you will ever see.
              CWT ISO with ERL-39, 15A switchers, 1000uF input caps, 30A schottky on each rail:
              And get this....Look at what Sun Pro was capable of. Double forward!
              The ISO PSU was sold a long time ago after being recapped, and that Sun Pro has been 90% finished for about 2 years
              • Drack
                Yup it's me
                • Nov 2016
                • 297
                • Venezuela
                #27
                What's left for the sun pro?
                • k370
                  Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                  by k370
                  I have a NM-A321 board that is dead, with no power at all.
                  When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                  With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                  • +3VALW
                  • +5VAUX
                  • 1.2VSUS_PWRGD
                  • 3VALW_PGD
                  • 1.05VAUX_PWRGD
                  Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                  The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                  09-23-2024, 11:57 AM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • corrize
                  Nikon D5 – dead, power board issue ?
                  by corrize
                  Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                  When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                  I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                  Now, I try to understand how it works.
                  There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                  04-03-2023, 09:13 AM
                • Asraf Atb
                  by Asraf Atb
                  01-27-2025, 05:02 PM
