5v rail to high
  • Longbow
    • Jun 2011
    • 623
    Re: 5v rail to high
    I'm still not buying it. I think it is time to name this supply and put up a schematic. These things are generally complex and well regulated supplies. True, they might need a simple load plug to actually draw a minimum current, but beyond that the 12v and 5v outputs should be right on.
    It applied to picture tube tv's and it applies to switching power supplies: these flyback things are like a balloon. If you grab one part and squeeze it (tweak it), another bubble appears in a different place. The whole group of secondary outputs work together, even if they aren't on the same secondary winding. If looking carefully at the schematic doesn't get results, I would scrap this one for parts. That's my personal opinion.
    Is it plugged in?
    • Drack
      Yup it's me
      • Nov 2016
      • 297
      • Venezuela
      Re: 5v rail to high
      Sadly this is the only PSU I have, well I have others but they are worst than this , you can't buy anything better here without being rich and I don't think you could get an schematic, it's an Agiler AGI-ps1000
      • Drack
        Yup it's me
        • Nov 2016
        • 297
        • Venezuela
        Re: 5v rail to high
        Hi guys, did someone find anything about the psu?
        • Drack
          Yup it's me
          • Nov 2016
          • 297
          • Venezuela
          Re: 5v rail to high
          Update: the PSU is working fine, one of the DMM that I use to measure the voltages was bad and the other one had some dirty tracks on the PCB which affected measurements and a bad negative lead, 12 volts it's actually 12.33 at idle and 12.16 at full load with prime 95 and furmark running and 5v is at 5.19 at idle and 5.27 at load everything stable, the capacitors are doing fine (at least visually) the PSU exhaust air is just warm so I think it'll be fine, also I only use this pic like 3 to 4 times a month. Again thanks for everything guys.
            • 31214
            Re: 5v rail to high
            lol
            you can never have too many meters.
            i have 5.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #26
              Re: 5v rail to high
              Yup, most of my cheap multimeter do that. I just have to rotate the dial several times to clean the oxidized contacts. After that, they read voltage okay... provided that their batteries are also good, of course (low battery = high voltage measurement.)
              i have 5.
              You can say that again.
              I have only 4, but two are Harbor Freight Tools freebies, so not great quality. Another one is a cheapie as well, but a little better than the HFT meters (and I put good probes on it, so that makes it considerably better ). So my only good meter is a Radio Shack one - the more expensive models (though I got it for cheap on eBay.) It's no Fluke, but it's a major step-up from any cheap or even entry-level decent meter.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                #27
                Re: 5v rail to high
                lol
                i have 5.
                I second that motion.
                Ive got a digital Uni-T, an older analog RadioShack, and the good 'ol' Fluke digital.
                Follow the white rabbit.
                • Drack
                  Yup it's me
                  • Nov 2016
                  • 297
                  • Venezuela
                  #28
                  Re: 5v rail to high
                  We had 3 meters in my house, I had an analog that never worked like it should, and 2 digitals, one died after 10+ years of abuse(my dad dropped it a lot and the case was all broken) and the yaxun that is still working but it came missing one of the Ball bearings that make pressure on the dial and some black gunk that affected measurements.
                  • Nagy Daniel
                    Lowest possible resistance on laptop motherboard rail - Guide Table request
                    by Nagy Daniel
                    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                    So, I generated a table with AI so I can...
                    03-04-2025, 08:24 AM
                  • bimole
                    Weird behavior on 3.3V rail of a CORSAIR CX600
                    by bimole
                    A colleague gave me an apparently ill CORSAIR CX600.
                    He told me that he heard a banging noise, and smelt the magic smoke.
                    After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                    I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                    It's another story on the 3.3V rail...
                    I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                    02-13-2025, 04:49 AM
                    by momaka
                    03-15-2023, 10:17 PM
                  • mkdj
                    Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                    by mkdj
                    Dear all,
                    I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                    I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                    Both N-Channel Mosfets: nothing odd
                    P-Channel MOSFET number 1:
                    source - drain : 117 kOhm
                    source - gate: 96 Ohm
                    gate - drain: 117 kOhm
                    P-Channel MOSFET...
                    08-20-2025, 06:08 AM
                  • dariusgc
                    Acer Nitro 5 AN515-55-53M3 (FH52M LA-J891P Rev: 1B) GPU memory rail
                    by dariusgc
                    Hello, i have Acer Nitro 5 AN515-55-53M3 (FH52M LA-J891P Rev: 1B), on GPU (nVidia RTX 2060) memory rail have ~0.5 Ohms resistance is it normal? or dead GPU?
                    Prehistory: There was short on main rail, ~0,1 Ohms. Problem was double mosfet AOE6930 who is feeding GPU memory rail, i changed it and short is gone, and laptop turns on, but discrete gpu wont' work, video drivers install was succesfull. Some
                    insights?​
                    10-07-2025, 09:38 AM
