DC boost converter max power ?
  • bianchi77
    • Jun 2016
    • 1121
    Re: DC boost converter max power ?
    I got 234mV on Vo for 47uH and 150KHz....
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      #82
      What is the output diode you are using?
      My pc
      CPU : AMD PHENOM II x4 @ 3.5Ghz
      MB : ASUS M4A89TD PRO USB3
      RAM : Kingston ValueRAM 16gb DDR3
      PSU : Cooler Master 850W Silent Pro
      GPU : ATI Radeon HD 6850
      • bianchi77
        • Jun 2016
        • 1121
        Diode = FR302 on frequency 921Hz, Vo = 216V and RL=7K..
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          #84
          fr302 = 100 reverse blocking voltage.
          you need FR304 at least.
          My pc
          • bianchi77
            • Jun 2016
            • 1121
            Fr107 ?
            • bianchi77
              • Jun 2016
              • 1121
              what happen if reverse blocking voltage is smaller than Vo ? will it reduce the output voltage ?
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                #87
                1N5822 40v not good enough
                FR107 1000v good up to 1000v will work for your application.
                My pc
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  #88
                  Wasted power as it goes backwards through diode.
                  My pc
                  • bianchi77
                    • Jun 2016
                    • 1121
                    Ok, I'll see your suggestion
                    • bianchi77
                      • Jun 2016
                      • 1121
                      so if the output voltage is larger than diode breakdown voltage, it will reverse backward through diode...I see
                      • bianchi77
                        • Jun 2016
                        • 1121
                        may be it will answer one of my puzzle...
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          #92
                          that is correct.
                          My pc
                          • bianchi77
                            • Jun 2016
                            • 1121
                            Nearly the same result with FR107 ...216V at RL = 7K
                            • bianchi77
                              • Jun 2016
                              • 1121
                              I'm thinking obtaining 330uH or 470uH inductor in one piece, since I'm using multiple inductors in series now, a lot flux loss down the wire, reducing efficiency a lot..
                              • joshnz
                                • Feb 2011
                                • 969
                                • New Zealand
                                #95
                                what are you supplying this with
                                if you use 330uf inductor use 15khz oscillator.
                                My pc
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  I'm using 12V ATX power supply...the output is 11.4V
                                  I put fuse for protection...
                                  • joshnz
                                    • Feb 2011
                                    • 969
                                    • New Zealand
                                    #97
                                    ATX power supply
                                    the power supply you are using maybe 5v regulated and will need a load on the 5v rail to provide good voltage and current on the 12v rail.
                                    My pc
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      do you mean I need to put 10 ohm 10W on 5V rail to get a good voltage and current on 12V rail ? I have 10 ohm 10W, I'll put it later on ..
                                      • joshnz
                                        • Feb 2011
                                        • 969
                                        • New Zealand
                                        #99
                                        another calck says 330uf inductor use 150khz oscillator.
                                        My pc
                                        • Khron
                                          • Sep 2006
                                          • 1350
                                          • Finland
                                          #100
                                          Thanks for the chip link, but that would be another month to wait, I'll buy it later on, but I'm interested to find a way to increase amperage for 555, this is what I have on my hand..
                                          There are only two explanations for that.
                                          1) The mail in Australia is using actual snails for delivery - highly unlikely
                                          OR
                                          2) The location in your profile is... incorrect (i was tempted to say BS at first).
                                          I don't want to think of a third possibility. Or actually, the "nicer" third possibility would be that you didn't even READ what i wrote in that post.
                                          I'm quite sure you didn't even click on that first result - the seller seems to be based in Croydon, Victoria.
                                          Are you trying to tell me a small envelope with 10 chips takes a whole friggin month to travel from Victoria to Western Australia? Or you really can't spare 5-6$?
                                          Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
