CORSAIR RM1000 - help needed!
  • Monument
    • May 2011
    • 40
    • Estonia
    Got a Corsair RM1000 PSU that kicked off main fuses in the building, found the fault but cant identify the diode, see the pictures below:
    If anyone could provide me some schematics, would be thankful!
    • 31037
    Re: CORSAIR RM1000 - help needed!
    if he face has blown off, it's still in there somewhere - give it a good shake.
    • Monument
      • May 2011
      • 40
      • Estonia
      There are no pieces, its been burned off I think.
        • 31037
        no, it split - i'm sure of it.
        • Monument
          • May 2011
          • 40
          • Estonia
          Nowhere to be found, searched for an hour, whats the purpouse of this diode`? Why did it make such a power outtage in the whole building?
            • 31037
            no idea, you have to trace the tracks.
            it may be the pfc circuit.
            • japlytic
              • Oct 2005
              • 2086
              It is the PFC rectifier, and two power MOSFETs for the PFC boost stage are near this rectifier - one possible match for this rectifier could be an ST STTH8L06.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                if you get it running replace the secondary caps.i see crap.
                • Quasam
                  • May 2015
                  • Norway
                  It's c3d10060
                  DIODE SCHOT 600V 10A
                  Now I need som help from you.
                  On the bottomside of the main pcb.
                  Could you read off numbers\values on the following components:
                  R508
                  R507
                  R510
                  R511
                  R514
                  R509
                  These and F3NK80Z (q501) got blown\cooked in a water damage incident.
                  Any help appreciated
                  • Ositronix
                    • Jun 2018
                    • Nigeria
                    hey guys, i am new to badcaps.net and need your help on the rm1000 power supply unit. the power supply got fried and on opening it. i found a burnt capacitor and a varactor(not so sure, the component in front of the diode with reference to the picture) leaving the fuse ok. i changed the burnt components and visually everything seems ok. but its not powering up. i need your help asap. thanks.
                    • Stefan Payne
                      • 1267
                      start with making pictures and uploading it to this forum...
                      • rayhan
                        • Nov 2018
                        • Bangladesh
                        if i replace it..it will be ok..?
