I've run out of known good PSU's for my current build, as 2 of them are suspected of damaging video cards. (I'll make a separate post with pictures for them)
My question is, for the following system, what are my options for buying new? Ive spent many hours recently looking for a new ATX v1.xx psu that has the -5 rail and isn't proprietary. The system will host the devices listed below, should be run 24x7 (Though i expect 2x a year or more to turn it off and on to swap drives in and out as well as to clean the dust out)
I'm currently using an LIC LC-350W power supply, which Ive gotten nervous about as ive read elsewhere in this forum that its a mobo killer. Hence my desire to get it quickly out and replaced.
I'm not looking to spend more then $30-$50. I'd prefer a new one that will last at least 3 years (Hopefully I'll have the space and motivation to start re-capping my questionable ones by then)
Thanks for your time!
Motherboard : Intel SE440BX-2
Memory: 512M PC100
CPU: Currently P2-400, awaiting P3-700
Hard drives: Main: WD cavier 7200 (hot little bugger!) inside Vantec ez-swap2
Other drives as needed for imaging/restoring from/to backups (max 3 ide/pata)
Optical: dvd-rw and/or 52x cd/cd-rw
AGP:
Voodoo 3 3000 (45 watt max, IIRC)
PCI:
Yamaha DS2416 (Unknown load. possibly 45-50 watt as its a 16-channel mixing/recording sound card)
4-port (2 external, 2 internal) Rosewill USB2 card. (15 watt?)
Kingston KNE-110tx ethernet (Realtek 8139) (5 Watt?)
ISA:
Soundblaster Awe32 CT3910
Misc: 2x 20mm? fans inside vantec case
2x 80mm case fans
1x pci/expansion slot exhaust cooler (underneath voodoo3)
Memory: 512M PC100
AGP:
PCI:
ISA:
2x 80mm case fans
Half of the computer problems is caused by bad contacts
(well, not quite, but we can agree that 70°C+ temperatures are not good for it.)
