Fortron FSP300-60PLN dead - solved.
  • kacper69
    • Dec 2006
    • 18
    If You have FSP300-60PLN power supply, whitch yesterday was worked , but today don't wont start, replace in this PSU capacitor C15 ( 33uF/35V ).
    master hoarder
    • May 2008
    • 12164
    • Bulgaria
    Re: Fortron FSP300-60PLN dead - solved.
    That faulty capacitor looks like Teapo SEK. I see more of those in the rest of the PSU. Definitely replace them too.
    • Behemot
      • 4845
      • CZ
      Replace all of them, I usually get these units with bloated SB output caps, often also others.
      • kacper69
        • Dec 2006
        • 18
        FSP Group INC. chainged design PCB in FSP300-60PLN power supply.
        But the problem "monday morning" was the same ;(
        In new design pcb very offen bloat 2 capacitors 1ooouF/1oV.
        After replaced this capacitors PS work OK.
        • jazzie366
          • May 2016
          • 304
          Replace the other Teapo caps as well.
          Popcorn.
          • Stefan Payne
            • 1267
            Replace _ALL_ Caps that are not the main bulk caps.
            ie every 5mm/6.3mm one, every one on the secondary side.
            For that you might have to desolder either the primary or the secondary heatsink and components connected to it.
            • Andreasbest
              [Solved] Fujitsu Lifebook E558 USB / HDMI / DisplayPort / LAN / 3.5" jack dead
              by Andreasbest
              Hello.
              I just solved a mystery with the right USB or HDMI/Displayport or Ethernet or 3.5" jack of Fujitsu Lifebook E558 going suddenly dead.
              I realized i had 6 pieces of the same model with the exact same issue, nothing on google, neither schematics so i had to dig in my self and provide feedback here in case someone else has the same issue.
              I found out that the USB daughterboard is connected to the mainboard with 2 wide and non bending flex tapes that are 2mm longer than they should and this results in a constant pressure on flex connector and therefore eventually it cracks...
              11-26-2024, 11:50 AM
            • double_DD
              How can I be sure that my EC chip is dead?
              by double_DD
              As the title suggests, how can I be sure that my EC chip is really dead?
              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
              03-12-2025, 07:47 AM
            • disorder
              ps5 edm-033 dead after hdmi/usb ports destroyed
              by disorder
              hello guys,
              i need help to repair a edm-033 ps2
              history : as always hdmi port and usb ports destroyed after unplugged
              after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
              so i changed it
              now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
              but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
              i don't see any projection of liquid metal on pcb.
              01-14-2025, 12:48 PM
            • Beton
              Finding a dead short component
              by Beton
              Hi guys!
              I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
              So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
              I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
              I have a bench PSU and if I try to inject voltage the voltage...
              12-10-2021, 01:05 PM
            • zunasthegreat
              Chieftec GPS-450-AA with dead 20N60C3
              by zunasthegreat
              Hello everyone hope all doing well!
              I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
              09-01-2024, 07:12 PM
