Corsair TX750
  • frogz81
    • Oct 2012
    • 31
    • Indonesia
    Corsair TX750
    Hi Guys,
    I need advise, i got TX750v1 yesterday, from previous owner he said this PSU kill soundcard's mobo and make his HDD error.
    So i need your help what part can cause the problem, where to start check?
    Check voltage:
    5Vsb : 5.1
    +5V : 5.13-5.14
    +12 : 12.12
    +3.3 : 3.41
    -12V : -12.2
    PG :5.1
    Thx.
  • frogz81
    • Oct 2012
    • 31
    • Indonesia
    Re: Corsair TX750
    Update,
    After checking there are no budging Capacitor,
    which part (rail) usually causes this problems.
    thanks.
      • 31017
      Re: Corsair TX750
      look for bad / cracked soldering - specially around any optoisolators.
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Re: Corsair TX750
        I don't think this PSU is what killed a hard disk or an integrated sound card (most sound cards are wrongly driven by unqualified persons or shocked by faulty Audio inputs) . Customers in most cases report erroneous conclusions . Maybe better test it for some time on another unit and see what will come up ..
        • frogz81
          • Oct 2012
          • 31
          • Indonesia
          Re: Corsair TX750
          I have experienced, psu can cause dead mobo's sound card (replacement 3x within the warranty period ). And problem resolved after changing the PSU.
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            Re: Corsair TX750
            Do you mean an integrated sound card (that mean they changed the mainboard 3 times ) was replaced 3 times under warranty ? , or your're talking about 3 pci express audio cards ?
            • frogz81
              • Oct 2012
              • 31
              • Indonesia
              Re: Corsair TX750
              Yes i mean an integrated sound card (changed the mainboard 3 times )
              • jiroy
                • Jun 2016
                • 2416
                • Lebanon
                Re: Corsair TX750
                I think the company seller whoever it is didn't give the right diagnosis or what was the real problem . No integrated sound card can be affected by a PSU due to many protections on the board itself . Lot of electronic components could fry , life fuses , diodes and even mosfets before an abnormal voltage reach the Audio circuit , assuming the board is new and warranty .
                Two options here , either a faulty Audio input from the customer or the seller didn't report the real problem (maybe they don't feel obliged to) , but the PSU has nothing to do in all this .
                • frogz81
                  • Oct 2012
                  • 31
                  • Indonesia
                  Re: Corsair TX750
                  hi all,
                  Update after take a break :
                  it's seems the problem at 3.3v rail, the rail become 5.3 v for 6-8 second and then get normal 3.4 volt without load.
                  which part/component i must checked. Already checked Capacitor output (12v, 5v, 3,3v rails) and in good condition capacity and esr.
                  thx
                  • nick122
                    • Jul 2016
                    • 108
                    • Slovenia
                    Re: Corsair TX750
                    Check the 3.3v rectifier
                    • h0m3w0rk
                      Random Shutdowns/Startup Failure with Corsair SFX 450
                      by h0m3w0rk
                      I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                      For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                      02-09-2025, 03:19 AM
                      Corsair CX750M [Model 75-002019] - burned output toroid inductor
                      by momaka
                      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                      09-19-2021, 08:44 PM
                    • hobostove
                      Corsair RM1000e - Help identify 5VSB Zener diode
                      by hobostove
                      Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                      Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                      There's a 22ohm resistor that's melted and open, but it still has the bands.
                      The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                      It looks like the diode connects the source and drain of a TNY284...
                      03-27-2025, 02:25 PM
                    • W1ngl3t
                      Corsair RM850x (synchronous ATX) need help troubleshooting
                      by W1ngl3t
                      I have a Corsair RM850x that refuses to turn on. I have 5v stby but as soon as I try to power it up it goes 'click' and does not deliver any voltages.
                      I have not been able to find any blown or shorted components and there are no bulging capacitors. I have replaced the APFC controller and for a brief period (2 or 3 on/off cycles) the PSU worked but then the fault returned. Perhaps heating the PFC area is what resulted in the temporary fix?
                      The only option I see now is to start pulling components one by one, but before I proceed, perhaps someone more knowledgeable...
                      03-15-2025, 04:43 PM
                    • bimole
                      Weird behavior on 3.3V rail of a CORSAIR CX600
                      by bimole
                      A colleague gave me an apparently ill CORSAIR CX600.
                      He told me that he heard a banging noise, and smelt the magic smoke.
                      After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                      I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                      It's another story on the 3.3V rail...
                      I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                      02-13-2025, 04:49 AM
