pc power supply
  • ydlazatp
    • Sep 2008
    pc power supply
    to the gurus,
    i have a problem with my psu and i cannot pinpoint the failing components.i test my psu without any load,the problem is once i short pin 14 and pin 15, the psu just ran for a seconds but i still got a 5volts standby.i already checked all the capacitors,diodes and transistors at secondary and all are good.im just new here thanks.
  • linuxguru
    • Apr 2005
    • 1564
    Re: pc power supply
    Try loading it with a dead drive. Basically, some PSUs will go into OVP shutdown without a minimum load on +5v and +12v.
    • ydlazatp
      • Sep 2008
      Re: pc power supply
      i tried to load 1 of my hdd but nothing happens,i noticed that 5vdc standby is 6vdc.what cause this standby voltage goes high?
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        Re: pc power supply
        post a pic.
        some units are better off in the trash.
        i would not connect it to anything i cared about.
        • linuxguru
          • Apr 2005
          • 1564
          Re: pc power supply
          Overvoltage on +5Vsb is almost always due to a failed small capacitor on the primary side of the auxiliary flyback supply. Look for a 22-100 uF, 35 - 50v cap near the auxiliary flyback transformer.
          • ydlazatp
            • Sep 2008
            Re: pc power supply
            thanks for suggestion,i look into that part.ill post my findings.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              03-31-2024, 02:12 PM
              07-01-2024, 06:34 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
            • CMCM
              Russound CA4 Power Supply Repair
              by CMCM
              Hello Everybody,
              Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
              Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
              The outputs marked 12v and 20v are all measuring only 1v.
              The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
              The capacitors physically look clean (no bludgesor leaks) and...
              07-03-2025, 01:12 PM
