Beckhoff I/O Lightbuss Coupler BK2000
    • Jul 2011
    • 6069
    Has anyone work on one of these units before BK2000 ?
    Or
    A Beckhoff KL2488 8 Channel Output Module ?
    Here is the problem I am having with is machine is that I am getting an light-buss error undefined
    meaning that unknown problem but if you power down the machine and power it back up It might work for awhile and then the same thing may happen two or three time that day or the next day
    Now the Beckhoff KL2488 8 Channel Output Module the LED indicators light for each channel that are lighting are very dim all the time I do not know if this mean any thing or not
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Beckhoff I/O Lightbuss Coupler BK2000
    Would it be a terrible idea to... i don't know... crack'em open and look for visual clues?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • Jul 2011
      • 6069
      I bought a use one of these off of eBay $20.00 Beckhoff BK2000 for me to see what is inside of one I am also going to buy one of these as well from eBay 2@ $20.00 Beckhoff KL2488
      I might be able to see if it is a power supply problem or not because two of the servo drives on this same machine have already been recapped because of drive errors
      Once recapped those errors have not come back so far but it has two more drive that have not been recapped but we have a spare drive for me to have time to recapped one at a time
      Now this machine is about 12 years
        • Jul 2011
        • 6069
        The problem is that this machine is used all day and every day
        It is very hard to shut it down to do this -- this is why I am buying used one to see just what is in side of it
        Last week I had to shut it down 1.25 days and with that
        we became three days behind for work on this machine
        I wish I could do that it would be easier
        For unrelated problem ----->
        • Khron
          • Sep 2006
          • 1350
          • Finland
          For 20$ a pop, why not just replace them outright? I mean, surely a day of downtime's gotta be worth WAY more than that...
            • Jul 2011
            • 6069
            Here why I can not do this is because the servo drive that I was talking about that we have spare one that cost $1500.00 and it has priority firmware in the drive you just can not get one off of shelf from eBay or PLC Direct let say for $800.00
            Which I try to do and found out that it has priority firmware for the company that make the machine
            And who know if this is not the same way
              • Jul 2011
              • 6069
              It may or may not see why above
              But when I get them I am going open them up and see what shape they are in first then
              I going to install them and see if it will work or not
              Now on the servo drive controller it has two board one is the power board you can change them around and they will work the second board is the controller with the firmware and that can not moved around
              I am hoping that this will be the same kind-a-thing where you have a power board and a controller board
                • Jul 2011
                • 6069
                On this tread post i ask if and one use ether of these units
                TOTX170A or TORX170
                https://www.badcaps.net/forum/showth...120#post686120
                After looking at the data sheet I am going to make a fiber optic cable tester from some of the part out of the BK2000 that I bought off of eBay
                I already built the tranmiter board and it works good now I have to build the reciver board then I can check all the fiber optic cables on this machine has and go from there
                Here is a photo of the power board of the BK2000
                I have a question about the surface mount caps on this board do these caps go bad often ?
                  • Jul 2011
                  • 6069
                  There are three boards in this BK2000
                  Power Board
                  Controller Board
                  Optic Sensor Board
                  Here is a photo of trasnmiter board
                  The receiver board I will build to tomorrow
                    • Jul 2011
                    • 6069
                    Here is the pin out on this board from left to right
                    (+5v ) (-)(unknown) (+5v) (-) (+5)
                    The reading on the 5 volt rail are very satable at 5.25 on each one
                      • Jul 2011
                      • 6069
                      Well I made the board and went to power it up with 24 volts instead 5 volts
                      It light up like a chirstmas tree
                      I had it adj for the power board on the BK2000
                      I had looked at so many data sheets that I forgot that this was 5 volts
                      Not a very good mistake i was not feeling very good about doing this
                      It been awhile that I hav done this type of mistake o well
                      I bought two more of the BK2000 hopefully I do NOT make the same mistake agian the TORX170 are new from a company in China for $53.00 and the BK2000 which has this part in it cost $21.00 plus $7.00 shipping
                        • 31246
                        show some good foto's of the boards in this thing.
                        • eccerr0r
                          old X58 triple channel board... memtest86 memory speed?
                          by eccerr0r
                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                          06-28-2025, 09:06 AM
                        • spleenharvester
                          Reverse engineering of 18650 4-channel tester
                          by spleenharvester
                          Hi friends
                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                          05-04-2025, 02:43 AM
                          ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                          This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 03:28 PM
                        • mikey5791
                          Help on car amplifier only one channel works
                          by mikey5791
                          Hi all forum members,
                          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                          08-06-2025, 10:36 PM
                        • CG2
                          Janome DC3050 Sewing Machine Pedal Resistance
                          by CG2
                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                          04-14-2023, 07:53 AM
