Need help diagnose dead Sunshine ATX235 power supply
  • mikey5791
    • 521
    • Malaysia
    Re: Need help diagnose dead Sunshine ATX235 power supply
    Anyone still reading this thread? Is this el cheapo chinese low quality psu worth the time to repair since I wish to use it as a learning experience; and it is not for use on any data sensitive pc. The likely usage will be for test bench on old 90's(Pentium 4) era motherboard.
    FYI, the C945 driver transistor on Q12 base is connected to pin 11 on collector output of KA7500B while C945 driver transistor on Q13 base is connected to pin 8 on collector output of KA7500B. Earlier on testing them off circuit with a DMM on diode test gives a near identical (between 591 to 594 ohm) result from a new C945 unit.
    Hoping to hear your generous and helpful reply. Thanking in advance.
    • mikey5791
      • 521
      • Malaysia
      This thread was posted about a month ago with limited response. I wonder if anyone still reading this? With my little knowledge I have tested almost every parts that I suspect to be at fault but the result doesn't seem to agree. I welcome any advice and do correct me if I am wrong.
      Thank you in advance.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        I am still reading, i just haven't noticed any activity in it lately.
        A working TV? How boring!
        • mikey5791
          • 521
          • Malaysia
          This morning I decided to recheck transistor on heat sink 1 by setting my DMM to diode test. The transistor label is SEC-C5027 which is a NPN Silicon Transistor Main High Voltage Chopper Trans.a 800V 3A collector current type.
          Looking at front side of trans,left pin is Base(B),middle pin is Collector(C) and right pin is Emitter(E). Touching black DMM probe to B & red probe to C gives "1" infinite reading. Then moving the red probe to E still gives "1" infinite reading.
          Then,swapping red probe to B & black probe to C also gives "1" infinite reading.
          I believe the results show this trans is shorted.
          Checking online for equivalent on C5027 yields just datasheet; so I am not too sure if my stock of trans such as ST13007, STP20NM60FP, STPR10, SBL1060CT, P60N06A, P60NF or STPR1020CT can be equivalent. I do not have stock of C5027 though and buying online is too costly on shipping.
          Appreciate anyone willing to share input on which trans can be replacement for C5027. Thank you in advance.
            NPN transistor: E-B junction Forward bias (red probe on B, black probe on E) test between E and B should show around 0.6V or so.
            C-B junction forward bias: red probe on B, black probe on C, the meter should then show around 0.6V.
            Meter showing 1 means over range, please read your meter manual. You should test the diode to see how the meter works when testing the diode, also read up on how to test transistor and diode.
            Btw you should test the suspect device off the board. Right now your meter is showing you have open junctions.
            • mikey5791
              • 521
              • Malaysia
              #26
              Took out the suspect C-5027 transistor off board and set my DMM to diode setting.
              By looking at front side of trans(facing label C-5027),left pin is Base(B),middle pin is Collector(C) and right pin is Emitter(E) and using red probe as "+" and black probe as "-"
              I got the following six readings:
              +B&-E= 552
              +E&-B=1
              +B&-C=538
              +C&-B=1
              +E&-C=1
              +C&-E=1
              The reading of 1 means over limit, I suspect the trans is open and is there a suitable
              equivalent I can use from my stock of ST13007, STP20NM60FP, STPR10, SBL1060CT, P60N06A, P60NF or STPR1020CT.
                The readings are correct.
                You need to look at how to test transistor and what the Transistor junctions are and how the transistor functions.
                Get yourself a diode and do the test, you will get the same result as when you test the E-B, and C-B junction, and of course the E-C junction should show over limit (open circuit).
                You will need to understand the device you are testing first then you will understand what the readings mean.
                And BTW, testing the device with DMM is not 100% accurate but will give some clues because the applied Voltage is not the same as what the device is exposed to in the circuit.
                • mikey5791
                  • 521
                  • Malaysia
                  #28
                  Today I desoldered heatsink 2 and all the attached schottky rectifier so
                  I can test any suspect part off circuit.
                  Looking at left side part from front label MOSPEC S10C40C, I designate
                  left pin as A1,middle pin as C,right pin as A2 and set my DMM to diode test.
                  Red probe + to A1 & black probe - to C=reads 126
                  Red probe + to A2 & black probe - to C=reads 126
                  Red probe + to C & black probe - to A1=reads 1 (overlimit)
                  Red probe + to C & black probe - to A2=reads 1 (overlimit)
                  Looking at middle part from front label PHOTRON PSR16C40CT, I designate
                  Red probe + to A1 & black probe - to C=reads 107
                  Red probe + to A2 & black probe - to C=reads 108
                  Looking at the right side double diode label FR302, on diode test I got one side reading as 1(overlimit), while the other side by swapping probes reads
                  406.
                  Still stumped at the above results which seemed to conclude all the three parts above are in normal range. So the problem of no power rail on 12V and 3.3V still lies somewhere else. Anyone has a clue? Many thanks for help.
                  • mikey5791
                    • 521
                    • Malaysia
                    #29
                    Reviving this old thread by desolder cap at C35 which is 1uF50v, tested esr is>4ohm.
                    So i replaced with a new cap of 1uF63v.
                    I force start the psu by shorting the green ps-on wire to ground. Then i switched on power.
                    The purple wire shows 5v as startup power. No other voltage like orange 3.3v or yellow 12v.
                    After about 5 minutes power on ,The fan start to spin. I got 3.3v,5v and 12v. Then i shut off power, restart power but fan not moving. Again i only got purple wire 5v and nothing else.
                    Can anyone help to explain why the psu slow to start up and kind to point me in what area to recheck. Thank you for advance help.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      #30
                      More bad capacitors, most likely. Try replacing the small capacitors on the secondary side.
                        • Jul 2011
                        • 6041
                        Originally posted by mikey5791
                        I also desoldered two small caps at C41 (2.2uF 50 V) & at C35 (1UF 50V) The small caps reads 3 ohm on ESR; are they alright?
                        It has been my experience that when you get an ESR value of more than 1.5 ohms this cap is bad compared to a new one with the same UF value
                        Most of the time I go by what the value of a new cap ESR compared to the cap that I am testing
                        and if I have any doubts about whether or not it good I just replace it
                        The value is about .900 to 1.3 ohms generally speaking
                        • mikey5791
                          • 521
                          • Malaysia
                          #32
                          Going back to this old thread, i had removed capacitors considered bad with esr value exceed 1.3 ohm. Removed caps at c26,c45 and c35(all are 1uf50v) and at c41(2.2uf50v),c32(100uf25v) and c10(470uf16v).
                          The bad news is my stock of new caps are just type 22uf16v and 470uf35v. Can this new caps be used for those i removed?
                          • mikey5791
                            • 521
                            • Malaysia
                            #33
                            Attached image of my stock of new caps.
                            Also image of front and back of the power supply after removing bad caps.
                            Appreciate any kind feedback.
                              • Jul 2011
                              • 6041
                              I also desoldered two small caps at C41 (2.2uF 50 V) & at C35 (1UF 50V) and the big coil. refer attached picture. The small caps reads 3 ohm on ESR; are they alright?
                              If you have this value for those caps they are way off the scale
                              It more like 1. Something ohms or lower than this
                              I would highly recommend that you replace those capacitor
                              And replace any capacitor that is lower than 100uf because they will probably have a high ESR value as well
                              This is just me but when I have problems with a switching power supply I replace all the capacitors except the main filtering capacitors
                              No you can substitute a higher value capacitor for those small UF value it probably will not work correctly
                              • mikey5791
                                • 521
                                • Malaysia
                                #35
                                Hi Sam (X3),
                                Very thankful for your reply. I am ordering online all the small caps which I removed. Also will post the result once all the small caps are installed.
                                Hope this ps full rail will work.
                                • mikey5791
                                  • 521
                                  • Malaysia
                                  #36
                                  Hi, i received my new caps yesterday and replaced all caps of 100uf and lower to new ones. Switched on power and still can only get about standby 5v dc on the purple wire.
                                  Not giving up, i took my DMM and remeasured output from primary side.
                                  First i probe on main primary capacitor which is abt 155v dc on each cap. Next thing done is a huge mistake by setting my dmm to dc scale, put the red + probe on cathode of diode at D7(A on image) while black - negative probe on negative leg of main cap(B on image). I briefly saw the dc voltage reading of 862v but a pop on my dmm. Btw, is it possible to get such a high dc voltage? I know this is a huge mistake now as my dmm not able to detect any dc now....it just show (1) forever.
                                  Can anyone point me what to do next to check on the psu? Thanks.
                                  • mikey5791
                                    Tiny Tech ATX480W output power ticking
                                    by mikey5791
                                    Hi to all forum members,
                                    ​​​​​​This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
                                    Fyi, i desoldered the secondary side electrolytic cap those over 1000uf...
                                    02-20-2025, 01:11 AM
                                  • asr
                                    Finding replacement diode iPad Pro 3rd gen A1701
                                    by asr
                                    Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                    Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                    07-09-2024, 06:24 PM
                                  • unimatrix93
                                    TV backlight zener diode
                                    by unimatrix93
                                    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                    The led strips has 9 6V leds.
                                    02-10-2025, 12:13 PM
                                  • wnlewis
                                    New wire for my RDE3340 Whirlpool electric range
                                    by wnlewis
                                    OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                    Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                    This is a Whirlpool RDE3340 electric range.
                                    The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                    Where may I find parts...
                                    01-08-2025, 11:21 PM
                                  • emeskay
                                    Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                    by emeskay
                                    We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                    08-06-2024, 07:13 AM
