ATX_PSU_5VSB_only
  • zodiac565
    • Jul 2013
    • 9
    • Austria
    ATX_PSU_5VSB_only
    i got this very new not older than 1-2 years Sharkoon WPM 600 V2
    the PSU doesn't turn on testing it with a motherboard+cpu(which work's fine with another PSU), it tries to start and the fans spin not quite a second before it shuts down.
    the power supply is very similar to this one tested and carefully documented on this site
    https://www.techpowerup.com/reviews/...L650AWT/4.html
    i replaced all the cheap Electrolytic capacitor's on the secondary side, near the output rails.
    the 'main PWM IC' CM6800TX got 0V on all pins in Power down state, (PS_ON left high).
    the 5VSB line showed 5V.
    a strange behavior come up when I tried to load the 5VSB line with a 22Ohm resistor (17Watt) the Voltage dropped down to 0.
    i see there are small caps around that 'standby PWM controller' TNY177PN
    which i guess is responsible for the 5VSB. should i replace these caps too ?.
  • CapLeaker
    Leaking Member
    • 8150
    Re: ATX_PSU_5VSB_only
    Try to heat up the caps with a hair dryer, then try to fire it up. See what happens...
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Yes, replace all of those small caps. Also make sure to replace the output caps on the 5VSB rail. Both can cause the issues you describe with the 5VSB.
      By the way, what brand and series are you using for your replacement capacitors? And where did you get them? (Hopefully NOT eBay!)
      • zodiac565
        • Jul 2013
        • 9
        • Austria
        Does nothing.
        yes i replaced now ALL of the Electrolytic Cap's. and still the same problem.
        I replaced them with caps i used to fix other power supplies and now they work again.
        i really don't now what part is, faulty. i think some of the SMD parts or the IC's.
        i would greatly appreciate professional help.
        this PSU got a date on it, its built in 2013.
          • 31017
          go over that with a magnifying glass - i see lots of cracked solder joints.
          hint: HALO's are for Angels - not solder joints!
          • zodiac565
            • Jul 2013
            • 9
            • Austria
            you mean solder joints that look like HALO's ? can you please give me an example through my picture.
              • 31017
              i may have missed a few, and some may just be the lighting.
              but you get the idea.
              • zodiac565
                • Jul 2013
                • 9
                • Austria
                yea thanks for that tip, i re-soldered some of bad looking solder joints.
                what now appears is, when i don't insert one cap of the 5VSB line (the one before the small coil placed on the output side). i get all voltages 3.3V 5.0V 12V when i pull the PS_on Low.
                if the cap is inserted still the same problem and no output voltages if PS_on Low.
                strange thing.
                  • 31017
                  maybe that one cap is bad
                  • CapLeaker
                    Leaking Member
                    • 8150
                    strange thing.
                    Any pictures of that?
                    • SoporteHR
                      Help please, Line + 5VSB increases the voltage.
                      by SoporteHR
                      Hello everyone, receive a cordial greeting.
                      I have an ATX 500W power source. Chassis Model: LPJ2-23.
                      It turns out that when measuring the line voltage + 5VSB. After the source is turned on, the voltage gradually increases until it reaches approximately 7.8 vdc.
                      If I leave it connected to the power but turned off, the voltage remains stable at 5.1vdc. approximate
                      I thought I was a capacitor in that sector. Then I measured them with the ESR Raptor and they measured me well,...
                      08-10-2019, 06:14 PM
                    • cubytus
                      Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                      by cubytus
                      Hi to all,
                      I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                      I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                      Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                      01-10-2024, 01:26 AM
                    • TrueSword88
                      Kogan - KALED65XU9220STB - Blue Vertical Line
                      by TrueSword88
                      Hi all.
                      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                      The line just happens to coincide with the end of COF and start of the next COF (attached).
                      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                      Hoping to fix...
                      05-05-2023, 04:28 PM
                    • прямо
                      Viper22A 5VSB circuit
                      by прямо
                      So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                      In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                      01-13-2024, 07:05 PM
                    • kotel studios
                      FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                      by kotel studios
                      Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                      Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                      I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                      Any ideas where to go next?
                      02-23-2025, 11:47 AM
