RadioShack 13.8v/3A power supply transistor ID/replacement.
  • FlyNN
    • Feb 2016
    • y
    Can anyone suggest a replacement transistor? This 13.8v power supply (RadioShack) blew up on me many years ago and I have been dragging it around knowing someday I would repair it. Well, this weekend I finally got around to popping the cover on it. Blown fuse, replaced. Checked main electrolytic capacitor, suprized that it checked OK. Looks like the power transistor is shorted though. Can't seem to find ANY data on a DVE 312 or a cross reference. This power supply seems to have been common with many other brand names. Any suggestions on a replacement for the DVE 312?
    Its good to be Alive!
    Re: RadioShack 13.8v/3A power supply transistor ID/replacement.
    More likely to be 2N3055 but we need to verify if it is NPN for sure.
    Need to see how Emitter and the Collector pins are connected.
    • zx8401
      Phantom Fiddler
      • Aug 2013
      • 49
      • uk
      Measure the voltage on the case of the transistor in respect to the black terminal, you should find 18-20 volts on it.
      A 2N3055 OR 2N3772 Should do, if the output is too high then check those two transistors on the main board, sometimes they are taken out by the fail of the 2n3055.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8148
        Originally posted by zx8401
        measure the voltage on the case of the transistor in respect to the black terminal, you should find 18-20 volts on it.
        A 2n3055 or 2n3772 should do, if the output is too high then check those two transistors on the main board, sometimes they are taken out by the fail of the 2n3055.
        x2
        • r2digital
          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
          by r2digital
          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
          04-18-2024, 03:50 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
        • Goldenmonkey
          Samsung pn59d530a3f no picture after power supply replacement
          by Goldenmonkey
          My samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
          after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
          Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
          04-07-2023, 09:39 AM
          07-01-2024, 06:34 AM
