I recently converted an old COBA VP-400X PSU into an adjustable lab bench power supply. I made it adjustable by using a WD2002SJ step up converter on the 12V rail.
A few days ago I hooked up a brushless DC motor from an old RC car. At first at 12V and then I cranked the voltage up to 28V for a short time just to see how the motor takes it.
That were the last moments of my power supply.
It did turn off without smoke or anything.
When I try to turn it on I get 5VSB and when trying to start the power supply I get a short pulse on +5V (I suspect also on +3.3V and +12V, but +5V is tied to a LED so I can see it) before it shuts off.
In the Inside there's a A109B V08 board from 2005 whose schematic seems to be pretty much the same as the one I attached. While doing some measurements I noticed that the power transistor Q3 (STD13007 in my case) gets its collector voltage (310V) but on the emitter side I get around 120V. These 120V start decreasing to 0 after my measurements. It does seem the power supply gets kicked on but couldn't keep up the oscillation.
So i measured the base Voltage, which decreases (after my measurement) from 13V to 0V.
My guess is that it just doesn't oscillate and I suspected the two transistors Q1 and Q2 (C1384) to be failed. I tried to measure the resistance between B, E and C and the lowest resistance ist around 700ohms. Am I right, that these transistors are broken? Am I right at all, that this is the oscillation circuit and that might be the cause? Could there be a short circuit I missed? Resistance between 3.3V and GND is around 7ohms but since I didn't use that rail I don't think that's the fault.
If I'm right, the transistors didn't fail as the only ones for sure. What should I check next? What might be the cause of all this trouble? Did the Motor draw too much current? was the current change to fast?
I hope someone can help me here.
Regards.
Edit: Since the image got resized here the original image: http://i.imgur.com/IFXl2tb.gif
Regards.
