The PSU is old , was received in good condition and the seal is intact. I did not want to open it, I just blew it with a compressor.
Meanwhile, I used it on different systems or to test various components.
As you can see it is a wide range of voltage source with 90 ~ 264V, active PFC and ATX2.0 standard-a fixed 24pin connector:
http://www.coolermaster.com/service/...l/RS-450-ACLY/.
I measured it with a DMM but with a dedicated tester - Thermaltake Dr.Power 2, and values are ok.
Works fine, but using of certain motherboards (DFI P35T52RL BloodIron, DFI NF4-SLI Expert and other old 2 to 3 mobos) fails to power on, restarting continuously, as if a malfunction of the motherboard.
What can cause this to occur?!
Thanks.
Thanks.
