Faulty generic 5V 2A AC adaptor ('wall wart')
    • 31163
    Re: Faulty generic 5V 2A AC adaptor ('wall wart')
    right, some advice about the kit before you build it.
    get a 16MHz crystal to replace the 8MHz one,
    get a 10pin box-header (2x5) like the ones used on motherboards for internal usb connectors.
    and get a usbasp clone on ebay to program it.
    http://www.ebay.com.au/itm/281783798957
    i'll sort you the software.
    • tiff_lee
      • Feb 2016
      • 17
      Nice one thanks for the pointers.
      I assume the 10 pin box header is to connect the programmer to but where on the pcb do you connect the header itself?
        • 31163
        you have to find some way of fixing it to the edge or something, then it's about 6 wires to the bottom of the cpu socket.
        i'v seen it done, if i remember where then i'll link foto's
        here is the hardcore answer btw.
        you could use a 6pin, but then you need an extra adapter to connect to the programmer.
        • tiff_lee
          • Feb 2016
          • 17
          Parts on order but it's china so will be a month no doubt.
          Thanks for the images, not sure on that 10 pin one though. It has TXD & RXD on pins 4 & 6 and looking at other pin outs (including images on ebay for other programmers) pins 4 through to 10 are all ground.
          http://cryoarchive.net/wp-content/up...asp_pinout.png
            • 31163
            ignore the txd & rxd - they are for some debug tools - not related to progamming.
            use the 6pin as reference of needed pins.
            your link is obsolete btw, designs change.
            i'm linking the schematic of the programmer.
              • 31163
              here you go.
              http://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg854124/#msg854124
                • 31163
                and this:
                http://www.banggood.com/Supporting-S...-p-989949.html
                • tiff_lee
                  • Feb 2016
                  • 17
                  Oh a case thanks saves me making one, plus with minor modding I can mount the 10 pin socket. I notice it slims down the zif socket.
                  On the colour screen one I have there is 3 test points labelled K A A although not too sure what they are for, although I think its for something to do with zeners given that if you put a resistor in there it gives results as if it's a zener.
                  Edit: My god there is so much 'stuff' on that website I could buy purely for gadget value it's scary
                    • 31163
                    you mean BangGood? yea i know - i can spend hours browsing that site!
                    the KAA is Kathode(lol) Anode, Anode - it's the zener tester and generates a relativly high voltage.
                    i also see that model has the InfraRed sensor and decoder in it - so it must be using the Markus Reschke AKA madires software.
                    that's mostly his thread i linked at EEVblog
                    • tiff_lee
                      • Feb 2016
                      • 17
                      I have browsed though the eevblog thread before but it's so huge you could spend an afternoon and then some reading it all.
                      I have no idea what you would actually use the IR sensor for, I mean I realise it detects IR but it what circumstance that is used? it does pick up something from my halogen desk lamp though and spits out a user & data code!
                        • 31163
                        for testing remotes - it decodes the data on the display!
                        btw, here is another long thread for you!
                        https://www.mikrocontroller.net/topic/248078
                        • tiff_lee
                          • Feb 2016
                          • 17
                          Oh yes all those IR codes and what not you can use to reprogram remotes, cool not that I think ill ever use that function personally.
                          More reading! thanks
                          • Behemot
                            • 4845
                            • CZ
                            #33
                            Oh man, 50 bucks for that open-source thing every chinese is building in their garage?
                            If I buy any switching power supply I change cap on site if they are NOT well know good brand name caps
                            This is a 5 volts @ 5 amp power supply
                            It had some green colored sleeve that had printed " Low ESR " on them no brand name
                            I know this a hack job how ever it had 2200uf@10 volt caps were 12mm Dia and 17mm tall
                            KYA 2700/6.3 D10x20 mm would be just OK, or KYB 2200/6.3 with lower ESR and longer rated endurance.
                              HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
                              This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                              09-06-2024, 08:50 AM
                            • jayjr1105
                              9v super basic wall wart issue
                              by jayjr1105
                              This is one of those worthless and time wasting repairs but it's bugging me and I want to figure it out. Simple 9v 1a SMPS wall wart and it's bouncing between 8.2 and 9.4v without load. I've pulled out every single cap and all tested fine. I've replaced the opto and same exact issue. All diodes are testing fine. I'm not sure if the IC can cause this or if the IC had issues you wouldn't get anything at all on output....
                              03-03-2022, 08:32 AM
                            • JarzabekPZ
                              HUAWEI Matebook D15 Bom-WDQ9 - faulty onboard RAM
                              by JarzabekPZ
                              I have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
                              08-08-2025, 03:40 AM
                            • Spudgun
                              Why doesn't current just bypass faulty capacitors.
                              by Spudgun
                              Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                              04-01-2025, 10:33 AM
                            • Simonc123
                              CH341A bios chip wont fit 1.8v adaptor holder
                              by Simonc123
                              Hi guys, I need a bit of help. I use a CH341A programmer, which is fine for 3.3v old-style bios chips. I need to reprogram some 1.8v chips, which are QFN type chips. I have the 1.8v adaptor for that slots onto the programmer, which does step the voltage down to 1.8v, but as you can see in the picture added, it doesn't fit in the IC holder.
                              Please see the 4th picture that shows what looks like what should work for the QFN IC (highlighted in red). The issue is that the 8 pads on the programmer are too long and short out the IC. Is it a case of putting kapton tape over the center ground...
                              03-09-2025, 08:54 AM
