need replacement transistor
  • xelectech
    retired tech
    • Nov 2014
    • 238
    hoping someone can ID or suggest a replacement for one found in an antec EA-500 psu:
    6 4 7
    6 L 4
    e c b
    It's a TO-92 case, the second line of #'s are spaced more widely. It's in the 5vsb ckt., I busted a lead off trying to remove some of the tan glue from it's legs.
  • SteveNielsen
    Retired Tech
    • 2327
    Re: need replacement transistor
    Google
    It's probably a 2sb647
    e c b is the pinout; emitter, collector, base
      How is the Transistor connected to other components? Good clear pictures of both sides of the board?
      • xelectech
        retired tech
        • Nov 2014
        • 238
        Originally posted by SteveNielsen
        Google
        >I did, tried bing, yahoo, digikey and mouser also, as well as alldatasheet
        >that may be it - at least they are both pnp's
        Thanks Steve
        • xelectech
          retired tech
          • Nov 2014
          • 238
          My good camera is down right now, it may be able to take a better pic of the bottom - the emitter was connect to R601 on the bottom of bd., (a surface mount one), the collector was connected to R602, (15 ohms) near the heatsink, right in the area where the purple wire is.
          I removed a 220uf 16v cap, which reads ok in esr and capacity. The transistor tests ok too, both diode junctions only read one way, about 640mV.
          Thanks Bud
          • SteveNielsen
            Retired Tech
            • 2327
            Their solder-wave must have been running cold, that blobby shit would have never made it past me when I did QA.
            • xelectech
              retired tech
              • Nov 2014
              • 238
              It is pretty ugly, rather hard to make out which component's leg is sticking through where -
              I don't think it's been worked on before, I put all the scratches on it trying to get rid of some whitish powdery stuff that was between the traces in several places.
              • japlytic
                • Oct 2005
                • 2086
                With Japanese transistor types, "2S" is usually omitted on the device markings, and I have seen some which also omit A/B/C/D markings.
                • xelectech
                  retired tech
                  • Nov 2014
                  • 238
                  Thanks for the info. I guess a comprehensive cross-reference book is a thing of the past now.
                    • 31015
                    put the old one on a tester to see if it's npn or pnp etc.
                    • xelectech
                      retired tech
                      • Nov 2014
                      • 238
                      Hey Steve, just wondering can you tell me if the surface-mounted components are put on the board before, or after, it goes through the wave-soldering operation?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        A good video showing wave soldering
                        https://www.youtube.com/watch?v=Ap-HY7qP9zE
                          At :34~36 you can see she twisted the black heatsinks for the SMD ICs, so the SMD components were already went through the SMD process before the wave soldering process.
                          • xelectech
                            retired tech
                            • Nov 2014
                            • 238
                            Thanks, I'll check that out next time I get to the library.
                            I have seen 2 different setups in operation, one at Spacelabs (a biomedical equipment mfgr.) in the early '80s, and another in the mid-80s at a dental xray equip. mfgr. - don't know when surface-mounted stuff came on the scene, but there wasn't any back then that I'm aware of.
                            • xelectech
                              retired tech
                              • Nov 2014
                              • 238
                              Kinda hard to do that, one of the legs is busted off flush - still possible to test the diode-junctions, though, it's a pnp.
                              • SteveNielsen
                                Retired Tech
                                • 2327
                                Where I worked they were just starting to test running boards with smt parts thru the solder wave and trying out different glues. This was quite some time ago and smt parts were not widely used yet.
                                  • 31015
                                  you do wave-solder smd
                                  to do it you need 2 things.
                                  1: you need to glue the parts down - annoys the hell out of me when i need to replace them!
                                  2: on chips you need larger pads on the end the wave flows towards to catch the solder before it bridges anything.
                                  you often see an arrow on these boards indicating the direction of the wave.
                                  • xelectech
                                    retired tech
                                    • Nov 2014
                                    • 238
                                    Interesting! Thanks
                                    • xelectech
                                      retired tech
                                      • Nov 2014
                                      • 238
                                      Looking for a suitable replacement still - I found a similar tranny in a psu (guess I should have mentioned that the broken one is in either a to92-L or to92-MOD, but I didn't know at the time), here's a couple datasheets, the 2sb647 being the original and the ksa928a being similar (but is it similar enough?)
                                      Not sure anything attached, can't see it in the preview...
                                      Nope, couldn't load the links - anyway, does anyone know if these two transistors are close enough that I can use the ksa928a in place of the 2sb647?
                                      Thanks for any insight...
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        http://alltransistors.com/crsearch.p...e=60&caps=TO92
                                        Type Designator: 2SB647
                                        Material of transistor: Si
                                        Polarity: PNP
                                        Maximum collector power dissipation (Pc), W: 0.9
                                        Maximum collector-base voltage |Ucb|, V: 100
                                        Maximum collector-emitter voltage |Uce|, V: 80
                                        Maximum emitter-base voltage |Ueb|, V: 0
                                        Maximum collector current |Ic max|, A: 1
                                        Maksimalna temperatura (Tj), °C: 125
                                        Transition frequency (ft), MHz: 70
                                        Collector capacitance (Cc), pF:
                                        Forward current transfer ratio (hFE), min: 60
                                        Type Designator: KSA928A
                                        Polarity: PNP
                                        Maximum collector power dissipation (Pc), W: 1
                                        Maximum collector-base voltage |Ucb|, V: 30
                                        Maximum collector-emitter voltage |Uce|, V: 30
                                        Maximum emitter-base voltage |Ueb|, V: 5
                                        Maximum collector current |Ic max|, A: 2
                                        Maksimalna temperatura (Tj), °C: 150
                                        Transition frequency (ft), MHz: 120
                                        Collector capacitance (Cc), pF: 48
                                        Forward current transfer ratio (hFE), min: 100
                                        • Haaheim
                                          Bias matching replacement transistor - Parasound 2250
                                          by Haaheim
                                          Hi guys!
                                          I am currently working on a Parasound 2250 (class AB), which had one defective channel. Components in the signal paths have been replaced, including an output transistor (2SC3519).
                                          According to the manufacturer, bias is adjusted by measuring 1-3mV across the output resistors. The original ones are completely fine around 1.5mV, but the replacement is not. Initially, I got a couple from eBay, assumed they were fake (they were) and was able to source a replacement locally. This exhibits similar behaviour, being around 0.6-0.8mV on its emitter resistor....
                                          05-13-2022, 12:45 PM
                                        • the_rem
                                          Unknown transformer : how to find a good replacement part ?
                                          by the_rem
                                          Hello guys,
                                          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                          04-23-2025, 01:48 AM
                                        • ezenia
                                          PS4 controller left stick potentiometer replacement issue
                                          by ezenia
                                          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                          09-30-2023, 02:19 PM
                                        • boosti45
                                          Macbook pro logic board replacement parts quesion
                                          by boosti45
                                          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                                          08-21-2024, 05:23 AM
                                        • RickyZA
                                          Help choosing replacement SMD transistor
                                          by RickyZA
                                          Hi there everyone,
                                          Im looking for a replacement transistor for my TV's logic board, unfortunately i had a newbie slip and shorted out the Pwr_On to the 20v rail with the mainboard connected, not very clever at all i know. Here is the damage.
                                          Transistor Close up
                                          Original Transistor Datasheet : RT1P141C Marked P1
                                          Main Board Schematic for transistor Reference: Service Manual / Main board Schematic Not the exact same model but im pretty sure they use the same transistors marked P1 which is the RT1P141C.
                                          My other question is...
                                          06-30-2017, 01:46 PM
