liteon D30573H - no power
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 661
    • samsara
    Only get 2.8V on 5VSB, no green LED, no fan spinning (or twitch).
    Being in storage for about a year.
    The vent of larger green cap, to the left to the smaller coil, is slightly bulged.
    Could that be causing it not to start?
    Does this PSU have "start up" cap (whatever that is), and could that be it?
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: liteon D30573H - no power
    5vsb output caps need to be checked/replaced.
    5vsb is generated with IC on this psu. Check for shorted/leaky diodes around the 5vsb circuit.
    • CapLeaker
      Leaking Member
      • 8297
      Actually it did start, other than that you wouldn't have any 2.8v. Something is holding it back. Maybe check the feedback circuit? Last week I had a different PSU doing exact the same thing only to find out it had a bad cap right in the beginning of the feedback circuit on the secondary.
      • socketa
        Asbelowsoabove
        • Jun 2014
        • 661
        • samsara
        That cap was a 10v 1000uf teapo SC, and it was bulging from underneath - also
        it meaused 400uf and 2.5 ESR
        Traced the positive terminal through a coil to the 5VSB rail.
        Replaced it with Suscon SD (does that sound good enough?) and works fine now.
        Was the 5VSB voltage feedback going to the input of a control chip, and because the output voltage was too low the chip refused to return a power good signal and liven up the other rails?
        • CapLeaker
          Leaking Member
          • 8297
          Nice fix! I don't have a schematic or trace... so I dunno what that cap is doing. It was just that recently I had this problem here:
          https://www.badcaps.net/forum/showthread.php?t=51953
            • 31161
            NO.
            use a Panasonic FR or some other decent cap.
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 661
              • samsara
              No FR caps on hand. And not viable to order.
              It's just going to be a backup PSU - possibly sitting in a box for years to come.
              How about Ltec LZG? It's ripple and ESR specs are in the same ball park as the faulty teapo cap.
              • CapLeaker
                Leaking Member
                • 8297
                Just put a better cap in it next time it is viable. Sometimes you just have to make do with whatever you have on hand. Happens to me quite often. It may not be perfect, but it will work for now.
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  Probably not a good idea either. A couple of relatively recent threads here show a bunch of LZG blowing up under relatively low thermal drudgery. Su'scon are known to quickly die under high heat conditions as well (IE LCD monitors). And the output of a flyback converter (+5VSB) means high ripple current.
                  However, neither Su'scon nor LTEC would be considered worse than Teapo (maybe a slight hair better). If this isn't a mission critical repair, I suppose it isn't a big deal. And the rest of the Teapo (and tiny LTEC?) capacitors probably aren't in great condition either, so if you didn't replace those maybe next time you get the unit out you could do so if you like, and maybe change the Su'scon for a nice Panasonic like stj said. Oh, and that's a Hipro, not a Lite-on.
                  • socketa
                    Asbelowsoabove
                    • Jun 2014
                    • 661
                    • samsara
                    The ESR meter shows the LTEC to have 0.030 ohms ESR
                    So removed the Suscon, and popped in the LTEC, and all runs fine.
                    Was nice to actually have fixed something - rather than the usual dead end.
                    • Behemot
                      • 4845
                      • CZ
                      Can send ya some NCC KZH or KZN dirty cheap…
                      • socketa
                        Asbelowsoabove
                        • Jun 2014
                        • 661
                        • samsara
                        Thanks bud, but it's cool.
                        I'm happy with that LTEC cap, since it's ESR and capacitance test good.
                        Now i know what might be the problem if it fails to start again.
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
                          09-06-2024, 05:59 AM
