Anoma ASPR0515
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    Anoma ASPR0515
    This is another Nortel 3x8 power supply made by Anoma exclusively for Northern Telecom. Dual voltage, first rail 5V, the other rail is 15V.
    This thing has a weird problem. It powers up, but only supplies half the voltage on both rails. 5V only has 2.6V. The 15V rail has 8.1V
    U3 = 10358 (dual ground sense amplifier?)
    U2 (next to the opto) = TL431
    Now as soon as I kill the AC, the voltage on the 2 output rails jump up to what they supposed to be, then fall off to zero V (bleeder resistor).
    Nothing sticks out, no shorts on the output if I take the bleeder resistor R9 out.
    So far I am guessing there is something wrong with the feedback circuit. Any help is appreciated.
    • 31281
    Re: Anoma ASPR0515
    something is not bolted to the sink.
    what controller does it use?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8351
      Re: Anoma ASPR0515
      That thing not bolted on the sink is a double diode. I thought it was bad, but it wasn't. That's how I found the bleeder resistor R9.
      U1 (TO220 package) is on that heat sink sandwiched between it and the transformer. I have no idea what it is. I can't read it, so I have to take it out. Whatever U1 is. center pin is GND right to the main filter cap.
      O.k. I found the problem and I fixed it. Bad 22uF 50V capacitor on C21. On picture #1, top left corner. There is a bigger capacitor and between it and the heat sink is then a smaller capacitor (C21). On the picture you can see like half of the capacitor. It has something to do with the feedback circuit, as the TL431 is there.
      So all is good and voltage rails are up and healthy.
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
      • bimole
        Weird behavior on 3.3V rail of a CORSAIR CX600
        by bimole
        A colleague gave me an apparently ill CORSAIR CX600.
        He told me that he heard a banging noise, and smelt the magic smoke.
        After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
        I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
        It's another story on the 3.3V rail...
        I have some devices to test deeply PSUs (scope, AC source, electronic load)...
        02-13-2025, 04:49 AM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
      • mkdj
        Acer TravelMate P214 - N19Q7 main power rail shorted to ground
        by mkdj
        Dear all,
        I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
        I have checked resistance across each of the 4 MOSFETS. I have the following readings:
        Both N-Channel Mosfets: nothing odd
        P-Channel MOSFET number 1:
        source - drain : 117 kOhm
        source - gate: 96 Ohm
        gate - drain: 117 kOhm
        P-Channel MOSFET...
        08-20-2025, 06:08 AM
