Dark Power Pro P7 750w
  • Bungz
    • May 2013
    • 133
    Hello
    I have a rather sick Be Quiet Dark Power PSU I stripped out of a machine a few months back.
    Previously this has worked perfectly so I am not sure what has happened.
    The 5V rail seems to have taken a dump. On boot, using a MM I can see the rail holds 5v fine for about 10 seconds then I get a audible whine (amplified with HD activity) and the rail goes all over the shop from 4.4-5v till the system restarts.
    So as I am not much of a fixer beyond cap replacement could anyone give me a pointer?
    Visually all looks reasonable.
    Thanks!
    • 31304
    Re: Dark Power Pro P7 750w
    could be a lot of things.
    bad rectifier,
    bad optoisolator,
    bad reference (xx431 type device)
    • Bungz
      • May 2013
      • 133
      I am thinking that due to its symptoms should I identify those parts it would be possible to remove and replace / test them.
      When I get time I will strip it down a little and remove all the rectifiers to get the heatsink out the way to see what is what.
        • 31304
        given it takes a while, the faulty part may be heating up
        so start with the rectifier(s)
        • Bungz
          • May 2013
          • 133
          That was my thinking, will try and get it in bits this weekend and update with pictures
          • Stefan Payne
            • 1267
            gotta love those huge capacitors on the modular PCB...
            Anyway:
            Have you checket +5VSB?
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Could also be a bad solder joint. Anything that looks dull or suspicious should be resoldered.
              • Behemot
                • 4845
                • CZ
                Isn't the input cap bulging? It looks like it, and it's crapxon, that's what they do.
                • Victor Moreira Silva
                  Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                  by Victor Moreira Silva
                  I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                  Well, my decice specs are the following:
                  Model: Acer Nitro 5 AN517-54-55T5
                  CPU: Intel Core i5-11400H
                  GPU: NVIDIA GeForce GTX 1650
                  Motherboard: GH51G LA-L181P Rev:1c
                  The symptom:
                  When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                  05-26-2025, 10:49 AM
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • madan1
                  DALI SUB E-12F class D, fluctuating power rail
                  by madan1
                  Good day everyone.
                  I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                  The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                  The normal value of the positive and negative power rails is +/- 43V.
                  The positive rail stays...
                  10-15-2025, 10:33 AM
