LEPA G1600-MA voltage drops under load
  • ciki022
    • Nov 2013
    • 48
    • Serbia
    Mentioned PS, LEPA G1600-MA, without load works fine, giving 12,25 V. But, under load, voltage drops to 10,5 - 10,8 V, and computers works 30 seconds to 1-2-5 minutes and then reboots.
    And the voltage drop same when one graphic card is attached or more.
    Everything looks normal, no bulged caps, no burnt out parts, what should I first check ?
    Link to this PS
    http://vr-zone.com/articles/lepa-g16...w/17999.html/4
    Thanks in advance
    Goran
  • Stefan Payne
    • 1267
    Re: LEPA G1600-MA voltage drops under load
    Only the +12V rail drops?
    What about +5VSB?
    • Behemot
      • 4845
      • CZ
      What do you measure with and where?
      • Instafixx
        Macbook A2179 820-01958
        by Instafixx
        Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
        The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
        I checked the Power Sequences below and found this -
        Once a valid external power source (Charger or battery) is connected, the following rails will come online.
        PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
        PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
        05-20-2023, 05:19 AM
      • rddube
        Lenovo L490 Ram voltage circuit malfunction
        by rddube
        Hello friends,
        Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
        I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
        07-15-2025, 04:41 PM
      • Fernon@Repair
        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
        by Fernon@Repair
        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
        VCCIO voltage ok
        VCCSA Voltage OK
        VCCPLL Voltage OK
        Ram Voltage ok
        RamVTT OK
        VPP 2.5 OK
        But No Core Voltage
        and i want to this vrm ic datasheet or pinout (ISL69269)
        anyone have this ic pinout voltages?...
        06-25-2025, 07:19 AM
      • AJ847.63e
        Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
        by AJ847.63e
        Hi Folks,
        Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
        I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
        The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
        05-06-2025, 10:37 PM
