Varistor for Bestec ATX0300 D5WC
  • TELVM
    • Oct 2012
    • 547
    • Spain
    Re: Varistor for Bestec ATX0300 D5WC
    Originally posted by momaka
    ... The two varistors in your PSU are installed across each 200V capacitor. The idea behind a varistor is to clamp any power surges that go beyond the 200V rating of the primary caps. If you put a 300V varistor, then it won't protect the capacitor. However, you can't use a 100V varistor either, because the voltage on each cap will be around 165V and may go up to 170 V when your line is 5% high. So that's why you need a varistor rated between 180-200V ...
    On my super-duper Oh Deer I installed two '175' between the bulk caps:
    On 230VAC they are in series and work like one single '350' of same Joule rating.
    Also installed one '300' MOV upstream from the rectifier bridge:
    • docchan2000
      Okidoki
      • Dec 2015
      • 11
      • Ph
      Update.
      Changed my varistor to 200v
      Found out that there is a fuse covered with black rubber that does not give a reading on the multimeter. That fix my problem. Thanks everyone.
      • docchan2000
        Okidoki
        • Dec 2015
        • 11
        • Ph
        Other pics
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Originally posted by docchan2000
          Update.
          Nice work.
          Yes, the fuse is covered like that on many Bestec PSUs. Make sure to insulate the new one, too, especially if it is a glass fuse (which looks like it is).
          • chth96
            How can I identify varistor which have been blew up?
            by chth96
            I mistakely pluged 100v japanese retro game console to 220v outlet.
            So It seems that glass fuse and varistor have been blew up.
            I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
            Is there any way to identify varistor type in my sega saturn PSU?
            Any reply would be appreciated.
            EDIT:
            It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
            11-26-2023, 08:52 AM
          • Guest
            A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
            by Guest
            Hello all!
            Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
            After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
            09-26-2024, 03:31 AM
          • ten-d
            Nippon Chemi-con 100uf 100v BP electrolytic cap
            by ten-d
            Hi all!
            I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
            01-30-2024, 05:18 PM
          • kalemaroni
            XGPro TL866II Plus BIOS 1.8v issues - noob assistance
            by kalemaroni
            I've finally bought myself a BIOS programmer XGPro TL866II Plus and am going through old donor boards and logging the BIOS's I have in stock and testing out reading and writing but having some issues with reading 1.8v BIOS's. I have bought the 1.8v adapter.
            The problem is it's detecting the BIOS's but not reading them. I bought a second 1.8v adapter from a different supplier and this one has a different chip on it as seen in pic but still doesn't work.
            I've attached pictures of the chip, the adapter and side views to show that it's straight and down all the way through....
            11-22-2025, 05:09 PM
          • Doesronnieevenlift
            Help a noob! Wson8 Pogo/Needle Adapters to read/Write
            by Doesronnieevenlift
            I had recently tried to reflash the bios on a dell latittude that has a Wson8 Chip however to no avail.
            My question is, Has anyone had much success using the Pogo/Needle adapters to read and write bios without removing the chip from the main board?
            I seem to struggling with the solder process wofh my reflow station and currently have 4 machines waiting for a bios mod/reflash.
            For context I have just ordered a EZP2019 SPI flash so this is what I would be using alongside the Pogo Adapter.
            Apologies if this is the wrong subcategory....
            06-22-2025, 04:51 AM
