LN46C530 Black Screen - CN802 unplugged still no backlight
  • zukdj
    • Jun 2012
    • 104
    My friend just gave me his Samsung 46" TV, he said he went to turn it on one day and there was nothing but the startup tone. Me, being a newbie to this stuff followed some basic direction on the forums because I'd like to give it to my son for his Xbox so he isn't on my TV all the time. Unplugging CN802 doesn't enable the backlight as it should, TV is still dark, the TV has a black screen (no dim light, nothing). With CN802 plugged in I get the startup tone but still no backlight, also the red led on the front flashes 5 times. It is only an educated guess but should I assume the power supply is bad and not powering up the backlights properly? I also do not get that defining "click" of a relay when I turn the TV on, just the tones. I looked at the capacitors and they don't appear bad, they aren't leaking or bulging but that doesn't mean they are bad I am told. Any help is greatly appreciated.
    Re: LN46C530 Black Screen - CN802 unplugged still no backlight
    You start a new thread in the TV section, and make sure to up load good clear pictures of the whole back side of the TV so we can see how all the boards are connected together.
    What is the power supply board P/N? BN44-?????
    • mmartell
      • Oct 2013
      • 3189
      Verify the power supply part number as budm said then see here about CI818
      https://www.badcaps.net/forum/showthread.php?t=47668
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
