Cisco pix 506 fw psu
  • Shodan486
    • Nov 2009
    • 203
    Hey there !
    Been a while since I visited this lovely site ! Hope everything's alright, saw some red notification up there, hope the admin & badcaps store ain't in no trouble !!!
    So I wanted to start my cisco trainings and stuff, hooked up my FW mentioned above to the PSU, worked one day. Did the same thing the next day, nothing. Dead. Tried the spare one - worked.
    Disassembled, investigated. The PSU looks OK, no burnt spots or parts. Providing the picture. There is one indication of a failure, fortunately. The place with caps and the regulator is ''ticking'' (not like a bomb ), producing the sound twice per second. I think it is the regulator, but that's why I'm writing in here - to ask you guys if I'm right. Providing pictures.
    Appreciate the help in advance !
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
    • 31294
    Re: Cisco pix 506 fw psu
    ticking is either a shorted output, or a bad startup capacitor.
    change the small cap c4 next to the control chip
    and check the diodes on the other side of the transformer
    • Shodan486
      • Nov 2009
      • 203
      Thanks for the advice !!
      The diodes show 470 and 778 values on the diode test. The regulators (the ones attached to the heatsink) show values between 400 - 650 when you measure the leads, but one of them shows 600 on one leg and beeps (short) on the other leg - which to me (since I'm an total amateur) is not a good sound. But I believe that removing the parts and measuring them outside the circuit is more reliable, thus will remove them and measure.
      Should I continue replacing the C4 cap if this has been discovered?
        • 31294
        it will last longer if you do, even f it's not the problem.
        make sure you use a low impedence one like a panasonic FC/M/R or a rubycon ZL for example
        • Behemot
          • 4845
          • CZ
          What's the original cap?
          • Shodan486
            • Nov 2009
            • 203
            25V 47uf Rubycon, which should be one of the best. Looking for a spare one now...
              • 31294
              what series of rubycon?
              • Shodan486
                • Nov 2009
                • 203
                ''YXF'' , those should be low impendance @ 105C
                  • 31294
                  yxf is entry level low, and it's obsolyte - think the lowest you can buy now is yxg
                  so it's pretty old.
                  • Behemot
                    • 4845
                    • CZ
                    But it's oil electrolyte if I am not mistaken so it should really work for ages. If you have a meter, try measuring it, if not, well than it's worth trying to replace it…
                      • 31294
                      yxf are good performers - specially in audio gear.
                      but they do fail if they are near heatsinks, i'v seen a few go.
                      • Shodan486
                        • Nov 2009
                        • 203
                        Why would they fail near heatsinks? Anyways, still haven't found a replacement one, I'm gonna hit the electro shop we have in the town tomorrow.
                          • 31294
                          capacitor lifespan is directly related to heat because the liquid in it can dry out or crystalise.
                          • Behemot
                            • 4845
                            • CZ
                            More like chemically react and create compounds which are solid, not liquid. Drying may be the case of water-based electrolytes, but it is not like there is water floating inside, it's chemically bonded too.
                            • Shodan486
                              • Nov 2009
                              • 203
                              Sure it's the heat that usually kills the caps, but I thought that it would be something else since you said you've seen a few go . Nevermind and thanks anyways stj, because Behemot here stated an interesting fact : " Create compounds which are solind, not liquid " . Behemot can you elaborate, please?
                              Meanwhile I'm gonna dig through my junk board to see if I can find that cap, motherboards have similar ones near the audio chip usually.
                                • 31294
                                i doubt a motherboard would have low esr near the audio chip.
                                you can probably use 100uf if it's easier to find.
                                • Shodan486
                                  • Nov 2009
                                  • 203
                                  Replacing the mentioned capacitor did no help. I've acquired all the other capacitors as well, I'll try to replace them all.
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2850
                                    • Greece
                                    Never seen a failed YXF in my life. If you ask me they are as reliable as caps can get.
                                    • Shodan486
                                      • Nov 2009
                                      • 203
                                      Measured it outta circuit - no problems at all, a slightly increased impendance only.
                                      • Behemot
                                        • 4845
                                        • CZ
                                        Originally posted by Shodan486
                                        Sure it's the heat that usually kills the caps, but I thought that it would be something else since you said you've seen a few go . Nevermind and thanks anyways stj, because Behemot here stated an interesting fact : " Create compounds which are solind, not liquid " . Behemot can you elaborate, please? .
                                        For example salts and other compounds. The electrolyte and the foils react and loose their function. Capacitance descreases, ESR increases.
                                        • fuxxy
                                          Cisco 2960-CX Not providing POE
                                          by fuxxy
                                          First off, I'm sorry if this is the wrong subforum - None of the others seemed to fit the description.
                                          I've got this Cisco 2960-CX. It works flawlessly otherwise, but won't provide POE to the ports.
                                          On initial inspection, U4701 (An SI3458) has a physical hole in the die. I replaced with another chip out of a dead 2960, and it immediately popped a new hole.
                                          All I've been able to pull up are datasheets for mosfets, and I'm not quite convinced this is a simple FET.
                                          Popping the die implies an overcurrent downstream, correct?
                                          03-05-2023, 07:11 PM
                                        • disorder
                                          HP 2311 display, 3.3v regulator fried, need help to replace
                                          by disorder
                                          hello,
                                          i have a hp display 2311 to repair, totaly dead
                                          on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                                          i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                                          thank you
                                          07-27-2025, 04:34 AM
                                        • bilux
                                          uP0109: 2A Ultra Low Dropout Linear Regulator equivalent substitute
                                          by bilux
                                          I want to find a replacement for uP0109 8pins, and i found this parts:
                                          uP0109 is "2A Ultra Low Dropout Linear Regulator"
                                          RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
                                          FP6137C is "2A BUS TERMINATION REGULATOR"
                                          can replace uP0109​ by RT9199 or FP6137C ?
                                          11-01-2024, 12:00 PM
                                        • taurtnt
                                          Help identifying AMCH073 regulator or finding a compatible replacement
                                          by taurtnt
                                          I’m trying to identify a step-down regulator marked AMCH073. It’s used on the PEX power rail of a graphics card. I can’t find any datasheet or info online.
                                          Here’s what I’ve observed:
                                          • It has a QFN-16 footprint, similar to NB670.
                                          • Pins 1, 2, 15, 16 are connected together and go to the inductor, so likely SW (switch node).
                                          • Pin 9 is connected to GND, which doesn’t match NB670 (where pin 9 is SW).
                                          • Pin 8 also seems to be tied to the same GND plane.
                                          • The chip only says AMCH073, no manufacturer logo or other markings....
                                          08-24-2025, 03:06 PM
                                        • playit
                                          diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
                                          by playit
                                          hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
                                          and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
                                          for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
                                          02-26-2025, 05:39 AM
