Part ID Help
  • 1beertap
    • Mar 2009
    • 219
    Part ID Help
    Hello All,
    I'm trying to identify and source this part. The letters are AH RY. Attached is a pic of it.
  • Behemot
    • 4845
    • CZ
    Re: Part ID Help
    According to this it is NPN transistor (it's SOT-23) but who knows with these tiny ones http://www.s-manuals.com/smd/ry
      • 31163
      Re: Part ID Help
      it could also be a switching regulator,
      that code matches a lot of parts.
      • Behemot
        • 4845
        • CZ
        Re: Part ID Help
        There is something which looks like Q5 on the PCB which leads to me to think it may actually be a transistor
        • SteveNielsen
          Retired Tech
          • 2327
          Re: Part ID Help
          What is the board from?
            Re: Part ID Help
            Good straight shot pictures of the whole board (top and bottom side) will help.
            It looks like it drives Inductor L6.
              • 31163
              Re: Part ID Help
              something like this?
              http://www.torexsemi.com/products/detail.php?id=240
              • Behemot
                • 4845
                • CZ
                Re: Part ID Help
                I see no SOT-23 in there.
                  • 31163
                  Re: Part ID Help
                  i see not SOT-23 on the board - 3 legs and a tab = SOT-89
                  • Behemot
                    • 4845
                    • CZ
                    Re: Part ID Help
                    Oh, right. But isn't it smaller than SOT-89? Seems to me. And there is still that Q5 (or Q9) marking on the board.
                      • 31163
                      Re: Part ID Help
                      SOT-89 is the small one, SOT-223 is the larger one.
                      i'm not saying that's the part, but i wouldnt be surprised if it was a similar part from that company.
                      • 1beertap
                        • Mar 2009
                        • 219
                        Re: Part ID Help
                        Thanks guys for trying but, I found the problem to be cold solder joint on one of the terminals. This board has 32 IrLEDs on it and is used with a camera to take pictures via a motion sensor. (A hunter's camera). Thanks again guys for trying.
                        • phorce1
                          • May 2016
                          • 5
                          Re: Part ID Help
                          Except that it's 16 LEDs rather than 32 I have that exact same board from a physically damaged camera sitting on my desk. The AH RY transistor, coil, and Yellow/Black/Red wiring are identical.
                          You didn't happen to take voltage readings on the red and yellow wires while you were working on it did you?
                          I'd like to power it up and use it for another camera project but I need to know if it wants 12V or if the camera pre-regulated it down to 5V. The LEDs are wired in 4 sets of 4 series runs from what I can see on the back of the board. The front is covered with a spacer designed to set the LEDs at equal height when they were soldered in. No way to remove it to look.
                          I haven't taken a meter to it yet.
