Re: OCZ 700 Watt Bug Zapper Recap & Repair
You should be using a series light bulb tester to reduce the voltage to the power supply. It would have saved the chip from utter destruction. Since the psu still has a short circuit the voltage would have divided between the bulb and the psu with the bulb having the greater voltage across it.
Half of the computer problems is caused by bad contacts
