The KING
  • everell
    • Jan 2009
    • 1514
    The KING
    Here is the KING, and I don't mean Elvis Presley! First thing to notice is that the brand sticker has been replaced. Residue from the old sticker is still present. I have no idea who the OEM is. This is a half bridge design. The fan was stuck. Every capacitor in the output circuits was bulging. So I replaced them all with some pullouts from my collection, increasing values a little. The main input capacitors were 330 uF/200 volts and were replaced with pull out 470 uF/200 volts. It did have pi output filters on the 5 volt rail and 3.3 volt rail. Single capacitor 1000 uF/16 volts on the 12 volt rail which I increased to 2200 uF/16 volts. The TO-220 output diodes on the 3.3 volt rail and 5 volt rail were replaced with shottky 30 amp 45 volt pullouts. The F12C20 output diode on the 12 volt rail was replaced with F16C20.
    On initial test, only a fan twitch. Found that the output diode on the 5 volt rail had one side shorted. That is why I "improved" the output diode arrangement.
    Second test with no load, the power supply came up running fine.
    For third test, I removed my I-Micro 400 watt power supply from my Pentium 3 test board (the I-Micro that blew up when tested with a Pentium 4 board). I installed the KING and powered up. NOTHING - just a black screen on the monitor. At least the CPU fan and power supply fans were running. A real disappointment considering that the I-Micro would at least power a Pentium 3 board.
    Here are some pictures of the KING with all repairs made.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: The KING
    Any chance some of the tiny JEEs are bad? Unless those didn't come with the unit. If the one driving the BJTs go, bad they can increase the switching losses of the BJTs, for one thing.
    • LDSisHere
      • May 2012
      • 727
      • U.S.A.
      Re: The KING
      For a cheap power supply I am surprised by the populated input protection, ceramic fuse and the use of headers for the power and fans.
      Did you check your voltages when powering the P3 board? Could it just be one rail sagging under load that affects the video chip set?
      • mockingbird
        • Dec 2008
        • 5484
        Re: The KING
        That looks maybe like a very old FSP design.
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          Re: The KING
          I bet PG is staying low, keeping the mobo in reset. Change those small caps near the '494 and power good ckt (near those transistors and gray wire).
          Also change any non-Jap caps on the secondary outputs.
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • everell
            • Jan 2009
            • 1514
            Re: The KING
            I don't know if it is FSP, but it is a very old design. Supervisory circuitry is all transistors, not the usual 339 integrated circuit. Date on the QC sticker is April 2003.
            • everell
              • Jan 2009
              • 1514
              Re: The KING
              You are correct......PG out is staying low. Looks like I have a lot of small capacitors to replace. This was supposed to be a KING, not a nuisance.
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                Re: The KING
                Hey, at least it's not thecapking!!!
                EOL it...
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1866
                  • Romania
                  Re: The KING
                  Actually,it's not a old FSP.
                  The OEM's Sun Pro. I don't know how you all didn't notice the KY-400ATX model number,specific for Sun Pro PSUs. Also the logo is very similar to Sun Pro's logo.
                  Main rig:
                  Gigabyte B75M-D3H
                  Core i5-3470 3.60GHz
                  16GB DDR3-1600
                  Samsung SH-224AB DVD-RW
                  Delux MG760 case
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Re: The KING
                    Correct!
                    Not only that, but the UL number, E210743, also matches what I have for a Sun-Pro built RaidMax RX-380K PSU.
                    Actually, here's a post I made on mine:
                    https://www.badcaps.net/forum/showpo...&postcount=883
                    Notice how similar the PCB designs are. Except yours has much more "beefier" parts and a mag-amp circuit for the 3.3V rail, whereas mine has a MOSFET and 3.3V rail is linearly regulated.
                    I deem that to be one of the worst PSUs I have (or maybe a close second after my JNC LC-235ATX). If you put better heatsinks in yours, it might be somewhat more use-able. The output toroid inductor actually looks of decent size. I guess this is as good and complete as this model gets. Like LDSisHere, I too am surprised to see connectors and a ceramic fuse. It's almost an OK PSU, actually ... well, almost .
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4961
                      • New Zealand
                      Re: The KING
                      King Yes? It should be called King No....
                      Must be some fault in the power good circuit, might not even be capacitors.
                      -David VanHorn
                      • everell
                        • Jan 2009
                        • 1514
                        Re: The KING
                        Model KY-400ATX.........does that mean this is supposed to be a 400 watt power supply.........sorta like the IMicro 400 watt power supplies?????
                        • kaboom
                          "Oh, Grouchy!"
                          • Jan 2011
                          • 2507
                          Re: The KING
                          Only on the sticker...
                          I'd say 150-175W with those stupid "T" heatsinks. Look at how little cross section there is behind/above the devices- how can that possibly conduct the heat well to the "top hat" where the holes are?
                          EOL it...
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            Re: The KING
                            Ah, but you see, diodes and rectifiers have a lower Vf at higher temperatures . Thus the PSU achieves higher efficiency .
                            On that note, all I have to say is, the Raidmax RX-380K that I pointed to in my above post was still very inefficient. It was used in a family friend's PC that drew maybe only 100W at the most (s462 AMD Athlon XP 2000+, GeForce FX5200, and one or two HDDs). This PSU always ran very hot and blew a lot of hot air, despite its fan being wired straight to 12V. So yeah, even with hot rectifiers, it was still miserably inefficient. You can see how "well-done" the PCB looks on my unit.
                            Everell, I sure hope the efficiency of your's isn't as terrible as that.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4961
                              • New Zealand
                              Re: The KING
                              -David VanHorn
                              • everell
                                • Jan 2009
                                • 1514
                                Re: The KING
                                kaboom, you are correct. I replaced eight small JEE capacitors in the area you indicated. The PG_out signal is now good. The KING will now power my Pentium 3 test motherboard just as good as the IMicro.
                                • Dan81
                                  SNES-powered
                                  • Oct 2013
                                  • 1866
                                  • Romania
                                  Re: The KING
                                  I'd be against trying it with a Pentium 4,considering how one of your IMicros (I see you had/have 3 of them) went off with a bang on a Pentium 4:
                                  With boldness, I attached it to a Pentium 4 class motherboard. Pushed PS_on switch.....BANG, fizz, and a small fireball! Both switching transistors shorted, the C945 driver transistors were bad, and the 7500 pwm chip was shorted. Also a couple of bad diodes, and the resistors in one of the switchers had blown resistors. I replaced the switching transistors with 13007. I also replaced the two electrolytic capacitors in the switching transistor circuits. Replaced the driver transformer just in case it shorted. Attached it to the Pentium 3 motherboard and once again it came to life.
                                  I still remember how my Sun Pro built Delux died...
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  16GB DDR3-1600
                                  Delux MG760 case
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    Re: The KING
                                    Wow, for that circuit not to work, that means those JEE caps really must have gone high ESR. I guess JEE really is that terrible .
                                    Was it something along the lines of...
                                    Press power button...
                                    Everything seems to be working?
                                    OK, time to do some computing!
                                    Then, all of a sudden...
                                    • Dan81
                                      SNES-powered
                                      • Oct 2013
                                      • 1866
                                      • Romania
                                      Re: The KING
                                      Nope. I was recapping it,then I assembled it together,and as soon as I flipped the power switch on it,it started fizzing and popping,and then it died.
                                      Main rig:
                                      Gigabyte B75M-D3H
                                      16GB DDR3-1600
                                      Delux MG760 case
                                      • everell
                                        • Jan 2009
                                        • 1514
                                        Re: The KING
                                        Was it powering a Pentium 3 or Pentium 4 type motherboard?
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                          HP Compaq Elite 8300 USFF PC | i5 Would it be possible to take the switching power supply and modify it for battery operation
                                          by sam_sam_sam
                                          I have pondered this idea for a while now and I would like for anyone who has any ideas for if this would work I have one that I might scariest it just to see if it could be done
                                          I am thinking it might be possible to get a battery pack configuration that should work but I not exactly sure if it feasible or not
                                          I was just looking at some HP elite 8300 computer that are used and the price has gone up since the last time I was looking at them on eBay really this sucks to find this out about a year ago you could find them with shipping for around $50.00 of course they have...
                                          07-07-2024, 03:01 PM
                                        • Mcfeetroy
                                          Fishing bite alarm drains battery
                                          by Mcfeetroy
                                          Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                          08-01-2025, 03:52 AM
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
