The KING
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    Re: The KING
    Originally posted by everell
    Was it powering a Pentium 3 or Pentium 4 type motherboard?
    Nothing. It had the jumpstart wire without the PSU attached to a motherboard.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
    • everell
      • Jan 2009
      • 1514
      Re: The KING
      Sounds like a great repair project! So did you fix it? That would be a real challenge for you. Post some pictures and tell us what all blew up.
      I did notice that my Sun Pro had terrific "cost out" features. The driver transistors did not have any 4148 protection diodes. There were no 4148 protection diodes in the base circuits of the switching transistors. With Power_Good low indicating a problem, the output voltages were present instead of shut down. Now I wonder if that ceramic fuse is really just a solid jumper wire!
      Two of my IMicro power supplies will handle all of my Pentium 3 and Pentium 4 boards. The other IMicro (the one that gave so much trouble) and the KING will handle the Pentium 3 board. So at least all are functional.
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • everell
        • Jan 2009
        • 1514
        Re: The KING
        Originally posted by momaka
        Wow, for that circuit not to work, that means those JEE caps really must have gone high ESR. I guess JEE really is that terrible
        Of the ten JEE small capacitors I replaced only three had bad readings:
        47 uF/16 volts measured 12 uF esr=10
        10 uF/50 volts measured 8 uF esr=5.3
        2.2 uF/50 volts measured esr=3.4
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          Re: The KING
          What about leakage?
          Years ago, I built a single supply audio preamp. So the inputs and outputs were floating at half B+ (biased with resistor chains), isolated by coupling caps.
          I used "recovered" caps of questionable origin and one channel didn't work. Turns out I lost bias because one of the caps was leaky- looked like a bad opamp. Even replaced the opamp to no avail.
          Finally got disgusted and stole some Nichicons from something else I built. Worked fine after that...
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • everell
            • Jan 2009
            • 1514
            Re: The KING
            Originally posted by kaboom
            What about leakage?
            Sorry, the ten small JEE capacitors have already been trashed. Even if the other seven were measuring good, I wouldn't trust them. So just as well that all ten are now Nichicon PW or Panasonic.
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              Re: The KING
              I hear ya...
              Don't forget the two 4.7u/50V caps in the base drive ckts for the two switchers.
              Have fun and good luck!
              EOL it...
              • everell
                • Jan 2009
                • 1514
                Re: The KING
                Those two capacitors were part of the ten that I replaced. They were 2.2 uF rather than 4.7 uF. The switching transistors were 13007.
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1866
                  #28
                  Re: The KING
                  I didn't. It was just not worth it,and 5vsb transistor along with a rectifier were both reduced to ashes. Literally paperthin heatsinks,crapcaps galore and and utter crap build quality.
                  I just gutted it and got a mid-to-high-end Deer that was already recapped with Rubycon MHZs (not fakes,I checked them twice),a few Teapos (I think they still work ) and Pannies. 5vsb Pannies. Also,rectifiers are all up to running a Pentium 4 (30A for 5v and 3.3v, 20A 60v rectifier for 12v )
                  This is the PC it powers now:
                  ASRock 775V88+
                  Pentium 4 3.00GHz LGA775 - EM64T support
                  Sony CDRW/DVD-ROM
                  40GB PATA HDD
                  320GB WDC SATA HDD - not connected atm,I have to wire up a SATA power cable since the normal 4pin Molex doesn't seem to work when used on this board.
                  ASUS Radeon HD3450 512MB
                  old PCI audio card I don't remember - filler card,unused
                  Realtek 8139C NIC
                  Winfast TV2000XP Deluxe - DScaler,since I'm going x64 this time
                  All these are powered by my Fortrex ST-400 (Deer) PSU. It's one of those PFC models by the way,and the PFC actually is real,not fake.
                  As for my old I-Micro,well,it's time had come and it was finally scrapped. I replaced it with a FSP FSP300-60GTP which I had to replace some bulged caps on. Removed the scorched 5v load resistor for safety reasons. (the heatshrink on it was literally ASHES!)
                  Main rig:
                  Gigabyte B75M-D3H
                  16GB DDR3-1600
                  Delux MG760 case
                  • everell
                    • Jan 2009
                    • 1514
                    Re: The KING
                    Was this your last working IMicro? One of the first IMicros I repaired is now powering a Pentium 3 733 Mhz motherboard pullout from a Compaq Deskpro ELN. Has been running several weeks.
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1866
                      #30
                      Re: The KING
                      Yes,this was my last (and only) working I-Micro (rebranded "Delux"). I scrapped it when I upgraded to an Athlon 64 X2 5600+ system,which was really power hungry (along with the usual stuff like 4 pin ATX12v cable it also required a 4 pin HDD/CD/DVD Molex cable) so I replaced it with the FSP which can take much more than the I-Micro.
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                      • everell
                        • Jan 2009
                        • 1514
                        Re: The KING
                        Now I feel like the last person in the world to have a working IMicro! I thought it was better than the Sun Pro (KING) in the first post in this thread.
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Re: The KING
                          I don't know....This doesn't look like a Sun Pro to me. The layout looks like it, but nothing else. It doesn't use the typical Sun Pro font for the "fuse warning," KT markings on the transformer (with a different font), an actual TI 494 chip. Also, I don't trust the UL number or KY-xxx number. I've seen a "Rhino" branded unit with the Sun Pro UL number, KY-450ATX model number, but a Leadman was inside. Gross!
                          • everell
                            • Jan 2009
                            • 1514
                            Re: The KING
                            Originally posted by pentium4
                            gross!
                            144?
                              master hoarder
                              • May 2008
                              • 12176
                              #34
                              Re: The KING
                              Could be that Sun Pro and Leadman are (or used to be) the same company - at least that is my theory anyways. I think Leadman used to have some low-end units that were very much like the KY-450ATX. Also, Leadman/PowMax and Sun Pro are the only two manufacturers that I know that use different size diodes for the bridge rectifier on the primary side (usually two big and two small ones).
                              Or perhaps Sun Pro copied some of Leadman's designs or cost cutting procedures. Either way, both companies make very crappy PSUs. Maybe some of Sun Pro's "high end" units aren't that bad. But still, I wouldn't spend money buying one.
                              • Nagy Daniel
                                Lowest possible resistance on laptop motherboard rail - Guide Table request
                                by Nagy Daniel
                                Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                So, I generated a table with AI so I can...
                                03-04-2025, 08:24 AM
                              • u666sa
                                HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                by u666sa
                                Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                Platform: ipa32 la-m024p rev 1b
                                Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                I found a short on the other side:
                                10-04-2025, 05:03 PM
                                HP Compaq Elite 8300 USFF PC | i5 Would it be possible to take the switching power supply and modify it for battery operation
                                I have pondered this idea for a while now and I would like for anyone who has any ideas for if this would work I have one that I might scariest it just to see if it could be done
                                I am thinking it might be possible to get a battery pack configuration that should work but I not exactly sure if it feasible or not
                                I was just looking at some HP elite 8300 computer that are used and the price has gone up since the last time I was looking at them on eBay really this sucks to find this out about a year ago you could find them with shipping for around $50.00 of course they have...
                                07-07-2024, 03:01 PM
                              • Mcfeetroy
                                Fishing bite alarm drains battery
                                by Mcfeetroy
                                Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                08-01-2025, 03:52 AM
                              • Victor Moreira Silva
                                Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                by Victor Moreira Silva
                                I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                Well, my decice specs are the following:
                                Model: Acer Nitro 5 AN517-54-55T5
                                CPU: Intel Core i5-11400H
                                GPU: NVIDIA GeForce GTX 1650
                                Motherboard: GH51G LA-L181P Rev:1c
                                The symptom:
                                When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                05-26-2025, 10:49 AM
