failed recap - antec true 380
  • moray
    • Jan 2008
    hoping someone can help me.
    I had a faulty antec true 380 psu.
    5 volt output was down to 4.5 volts.
    I opened it up and found bulging caps 4700uf f*yous.
    I sourced and fitted replacement caps, also replacing the 3300uf and 1000uf ones just to be sure.
    I now cant get it to power on at all.
    about 5 seconds after removing power it has a high pitched whistle.
    I have had a close look at the board and all the solder joints look ok, and all the components likewise.
    does anyone here have any ideas as to where to start looking to make this psu work again ?
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: failed recap - antec true 380
    Did you check caps polarity before the replacement? Electrolytics won't work if their polarity is reversed: they'll fail in a few minutes, sometimes they can explode too.
    Zandrax
    Have an happy life.
    • moray
      • Jan 2008
      thanks for your reply, yes I made sure I got the polarity correct, I double checked just to make sure.
      I have managed to resolve the issue, I used my multimeter probe and a toothbrush to scrape away all the flux around the solder joints.
      I tried it again and it's all good
      4.93 volts on the 5 volt line
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        So it was some dirt near solderings.
        It seems you saved an otherwise valid Antec from power supplies' paradise: nice job.
        Zandrax
        Have an happy life.
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
          by momaka
          03-15-2023, 10:17 PM
        • Dev Goose
          Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
          by Dev Goose
          Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
          What Happened
          The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
          12-13-2024, 03:13 AM
        • rabbituk
          Antec TruePower 380p failed after intermittent supply, suspect MOV
          by rabbituk
          I have an Antec TruePower 380p PSU that I had repurposed from a Sonata case. It had been working fine on a server in the loft using the Wake-on-LAN feature regularly until a couple of recent power outages where the power became very unstable - going on/off very quickly. There is now no output whatsoever from the PSU & fan isn't working. There was a pop when I attempted to turn it on.
          Upon examination, it appears that voltage isn't getting very far so I believe the immediate issue is within the first stage. There is a green component that I am not familiar...
          12-01-2020, 03:26 AM
          no-name Radeon 9600 XT recap and cooler
          by momaka
          I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
          This one was actually suggested to me by ChaosLegionnaire....
          11-06-2020, 07:54 PM
