PSU worth replacing caps?
  • mikay786
    • Aug 2014
    • 765
    Re: PSU worth replacing caps?
    Got it up and running now stress testing with 2 X gtx 285 on heaven benchmark pulling 530w from the wall. Seems to be working fine.
    Had some issues with the fan, both connectors where it was plugged in were not working for some reason. Couldn't be bothered figuring out why so soldered a slower rpm fan to the 5v and ground rails off the PCB. Just a nice whush so not loud at all.
    Will leave running for 3-4 hours
      • 31040
      maybe the fan problem is what took out the old caps!
      did the fans work before the recap?
      • mikay786
        • Aug 2014
        • 765
        Don't know to be honest, I wasn't paying attention to it.
        The actual fan works, I tested outside the PSU, just doesn't work in the PSU.
        I measured the pins on the board and were showing current, perhaps the fan controller is borked.
          • 31040
          i always bypass controllers.
          i like the fan 100% so it extracts air from the pc aswell as cooling the psu.
          before you say anything, i dont give a fuck about fan noise,.
          you wouldnt notice it in the enviroment i use pc's anyway!
          • c_hegge
            • Sep 2009
            • 5219
            Originally posted by stj
            carefull with that, it comes in 3 types.
            acid base, alkaline base, and neutral base.
            obviously you want the last one!
            Yup. I've used neutral base silicone before, and it works well. Roof and Gutter silicone is also a good option - it is designed to be used on steel, and so it has to be non-corrosive.
            • Noodneek
              Replacing all the caps on the BenQ SW2700pt's power board didn't help...
              by Noodneek
              My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
              I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
              08-30-2024, 12:52 PM
            • kotel studios
              TAGAN TG380-U01 PSU - 5v shorted after replacing caps
              by kotel studios
              Hi
              Recently I got this tagan tg380-u01 PSU with bad caps on 3.3v rail (the line was 2.5v no load!). Replaced them but no go, so I've replaced all of them, apart from some smaller ones and one under the secondary heatsink. Even that didn't help so I've replaced the others. All caps are known good ones.
              Powered it on and heard the breaker pop. Opened it up and saw some smaller caps shorted together. Fixed that up but still it trips breakers. Now I get 0ohms from 5v to GND. Secondary heatsink removed and still a short, even with the PWM IC board removed. All diodes on that...
              02-14-2025, 10:10 AM
            • bulkchart32
              are these caps good for replacing the ones in front of the cpu/gpu on an original xbox?
              by bulkchart32
              nichicon
              1500 µF 16 V Aluminum - Polymer Capacitors Radial, Can 8mOhm 2000 Hrs @ 105°C
              are what​ i used because i had heard the voltage doesn't matter as long as it is more than the original cap. i'm now reading that high voltage may make the cap's esr too high. is this a good cap for replacing those oem ones?
              05-14-2025, 02:12 PM
            • Delicieuxz
              Replacing caps in an old speaker system. Should I use a higher value here?
              by Delicieuxz
              I'm recapping an old Creative Labs / Cambridge speaker system / subwoofer. At 4:33 in this video, the person looking at what he says are the speaker caps in the system says they are 470 uF, and that he'd use much larger caps if he was building it.
              https://youtu.be/1LRIzePlma0?t=273
              I'm wondering if I should use something larger for the recap job, and what using larger caps will do for it.
              Would 680uF be good value to try in place of the 470uF originals?
              06-25-2023, 08:27 PM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
