PSU worth replacing caps?
  • Behemot
    • 4845
    • CZ
    Re: PSU worth replacing caps?
    Thanks for pics. Looks like some chinese spin-off to me, it indeed is Samson, not Samxon, they copied their GF series lol. Maybe Man Yue really made those for some garage brand, who knows, anyway, I guess they will tell me they have nothing in common with that and can't make it.
    I think you may be able to fit the KYA 3300/6,3 in there, or KZN 1500/6,3 is safe option. To my knowledge there is no quality 2200/6,3 D8 cap suitable there and most of the 1800/6,3 are too low ESR and short lifetime.
    Anyway for 1100 W I would use all D10 caps 3300 uF and those 16V (on +12V rail) KZN, such powerfull units can benefit from high capacity and low ESR/high ripple current.
    • mikay786
      • Aug 2014
      • 765
      That's fine, so you can supply for all A-H?
        • 31090
        aaaa fuck!
        none of those caps actually exist in the makers datasheets!
        o.k. i'll have to just find stuff that will fit and work.
        probably a combination of panasonic FR and FK series.
        btw, dont overlook small caps - if you cant reach them - use longnose pliers.
        • Behemot
          • 4845
          • CZ
          Originally posted by mikay786
          A) 2 x Toshin Kogyo 3300uF 10v (UTWKZ) D 10mm H 30mm
          B) 1 X Toshin Kogyo 2200uF 16v (UTWKZ) D 10mm H 25mm
          C) 2 x Capxon 3300uF 16v (C725) D 10mm H 30mm
          D) 1 x Capxon 2200uF 10v (C723) D 8.2mm H 25mm
          E) 2 x Samson 2200uF 10v (SGF) D 10mm H 20mm
          F) 1 x Samson 470uF 16v (SKM0702) D 8.2mm H 15mm
          G) 1 X Samson 220uF 16v (SKM0702) D 6.2mm H 10mm
          H) 1 x Samson 2200uF 10v (SGF0702) D 8.2mm H 30mm
          A, E -> NCC KYA 3300/6,3
          B, C -> NCC KZN 3300/16
          D, H -> NCC KZN 1500/6,3
          F -> NCC KZM 470/16 (or KZH 680/16)
          G -> Rubycon YXJ 220/25
          Alltogether it seems to be for 123 CZK or about 3,2 in sterling. Shipping seems to be 90 or 2,4.
            • 31090
            well i managed:
            A) 2 x Toshin Kogyo 3300uF 10v (UTWKZ) 10mm > EEUFK1A272L <2700uf
            B) 1 X Toshin Kogyo 2200uF 16v (UTWKZ) 10mm > EEUFK1C222L
            E) 2 x Samson 2200uF 10v (SGF) 10mm > EEUFR1A222L
            F) 1 x Samson 470uF 16v (SKM) 8mm > EEUFR1C471
            G) 1 X Samson 220uF 16v (SKM) 6.3mm > EEUFR1C221
            all panasonic from farnell
            • Behemot
              • 4845
              • CZ
              #26
              There is no reason to use only 2200uF caps in 1100watt unit, I wonder why they even used them, its way too small capacity.
              I searched for some reviews, there are not many, HardOCP measured 60 mV on +12 V, TweakTown about 100 mV on similar platform in Tagan.
                • 31090
                you are far too trusting in labels.
                i dont think i trust the label on anything after AT supplies.
                AT stuff was well built and honest about power output.
                • Behemot
                  • 4845
                  • CZ
                  #28
                  Wut?
                    • 31090
                    ATX labels are full of lies.
                    • Behemot
                      • 4845
                      • CZ
                      #30
                      Originally posted by Behemot
                      KYBs 2200/16 (D10x30) are on the way though it is getting somewhat longer. I expect them by late august/beginning of september.
                      Finally just got oder confirmation, they say delivery date is late october, eh…they should come with KZH 1200/6,3 (D8x15) and KYB 680/35 (D10x20).
                      What do you mean? That they have not actually loaded the unit with 1100 watts and they've been actually daydreaming and it burned at 800 watts or? http://www.hardocp.com/article/2008/...6#.VZ_N1ENIX6M
                        • 31090
                        these tests are run for hours at the most, not days or weeks.
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          This is a good PSU. It'll do its rated wattage. Maybe only @25C but still. It's the same platform as this ePower:
                          Only full bridge unit I've ever seen. Did yours come with a San Ace fan?
                          Samson caps are horrible, I'd put them down there with Jee/Rulycon. Glad you're replacing all the caps! I'd be curious to know the capacitance and ESR of the caps you pulled.
                          • mikay786
                            • Aug 2014
                            • 765
                            Cheers guys, much appreciated
                            • mikay786
                              • Aug 2014
                              • 765
                              Behemot, got to a 3 smaller caps and removed them
                              I) 2 x Capxon 47uF 25v (C729) D 5.2mm H 12mm
                              J) 1 x Samson 22uF 50v (SKM0702) D 5.2MM H 12mm
                                • 31090
                                I) 2 x Capxon 47uF 25v (C729) D 5.2mm H 12mm > EEUFR1E470
                                J) 1 x Samson 22uF 50v (SKM0702) D 5.2MM H 12mm > EEUFR1H220
                                • mikay786
                                  • Aug 2014
                                  • 765
                                  Thanks stj,
                                  Did you have anything for C/D/H?
                                    • 31090
                                    not panasonic i dont.
                                    i could look at some Rubycon and NCC etc datasheets later.
                                    but those 8mm ones are a bastard, those ratings are usually 10mm in diameter.
                                    • mikay786
                                      • Aug 2014
                                      • 765
                                      any 10mm ones, as should be able to fit
                                        • 31090
                                        double check that if i where you.
                                        you have some 10mm caps - see if you can fit them in the 8mm spaces.
                                        also that 10mm 3300uf cap would normally be 12.5mm
                                        • mikay786
                                          • Aug 2014
                                          • 765
                                          Does it matter if they touch? its tight but I can squeeze 10mm ones in there
                                          • Noodneek
                                            Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                                            by Noodneek
                                            My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                                            I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                                            08-30-2024, 12:52 PM
                                          • kotel studios
                                            TAGAN TG380-U01 PSU - 5v shorted after replacing caps
                                            by kotel studios
                                            Hi
                                            Recently I got this tagan tg380-u01 PSU with bad caps on 3.3v rail (the line was 2.5v no load!). Replaced them but no go, so I've replaced all of them, apart from some smaller ones and one under the secondary heatsink. Even that didn't help so I've replaced the others. All caps are known good ones.
                                            Powered it on and heard the breaker pop. Opened it up and saw some smaller caps shorted together. Fixed that up but still it trips breakers. Now I get 0ohms from 5v to GND. Secondary heatsink removed and still a short, even with the PWM IC board removed. All diodes on that...
                                            02-14-2025, 10:10 AM
                                          • bulkchart32
                                            are these caps good for replacing the ones in front of the cpu/gpu on an original xbox?
                                            by bulkchart32
                                            nichicon
                                            1500 µF 16 V Aluminum - Polymer Capacitors Radial, Can 8mOhm 2000 Hrs @ 105°C
                                            are what​ i used because i had heard the voltage doesn't matter as long as it is more than the original cap. i'm now reading that high voltage may make the cap's esr too high. is this a good cap for replacing those oem ones?
                                            05-14-2025, 02:12 PM
                                          • Delicieuxz
                                            Replacing caps in an old speaker system. Should I use a higher value here?
                                            by Delicieuxz
                                            I'm recapping an old Creative Labs / Cambridge speaker system / subwoofer. At 4:33 in this video, the person looking at what he says are the speaker caps in the system says they are 470 uF, and that he'd use much larger caps if he was building it.
                                            https://youtu.be/1LRIzePlma0?t=273
                                            I'm wondering if I should use something larger for the recap job, and what using larger caps will do for it.
                                            Would 680uF be good value to try in place of the 470uF originals?
                                            06-25-2023, 08:27 PM
                                          • Paxman_Swede
                                            by Paxman_Swede
                                            Hello!
                                            01-14-2025, 09:51 AM
