stop electricity meter method
  • necatduman
    replied
    Re: stop electricity meter method
    still current
  • necatduman
    replied
    This 2- LED infrared light captured hours of work we want to do the work I wanted to work on the device
    replied
    https://en.wikipedia.org/wiki/IEC_62056
    replied
    so you want to lock it into "night tariff" ?
    you would need to use an ultrasonic probe to break the clock crystal during the night.
    but to do that you would need the cover off.
    or you may be able to reprogram it using the infrared interface on the front - if it is badly designed!
  • necatduman
    replied
    There are two LEDs here one day and one night in a schedule to stop sending these LEDs signal bilirmiyim
  • necatduman
    replied
    hh
    replied
    Originally posted by necatduman
    We know how to reduce the speed of the electric meter you burn fuel to make such a circuit 30kwatt to 100kwatt bilirmiyim
    Ha? so you already KNOW how to reduce the speed of the meter, so why do you ask about the way to do it then?
  • necatduman
    replied
    replied
    Yeah, the Russian corporate terrorist.
    replied
    well it *was* free in Libya.
    btw.
    http://www.euronews.com/2015/06/23/a...ns-of-arrests/
    everybody is getting sick of these corporate terrorists exploiting them.
    replied
    "it's fair, they rob us - so why not rob them!" LOL, why not just remove it then and tell them you want free electricity, free food, free housing, free cars, free computers, free TV, etc.?
    replied
    personally i would just run a 100a concentric feed from further away from the house.
    replied
    It sounds like it to me, trying to pay less to the electric company.
  • SteveNielsen
    replied
    Excuse me but what's the point here? To get free electric power? I am sure there are laws against that in Turkey.
    replied
    The purpose of modifying this meter so you can use lots of power but pay less money to the Electric company?
    http://urunler.makel.com.tr/index.ph...-sayaclar.html
  • necatduman
    replied
    What we need to do to stop it for this device do you have anyThis counter circuit
    replied
    probably induction coil inside - so you need to generate a 50hz magnetic field.
    problem is, you may make it run faster.
  • necatduman
    replied
    attached house counter that shows how many kvatt oil counter this counter month we HAVE USED TV refrigerator washing machine 150TL will stop burning less fuel or electricity How we do these devices that we run counte
    replied
    it's not a counter.
    it's a microcontroller that monitors the current flowing through the meter and then display's it.
    if you want to mess it up without opening the case then all i can think of is using a strong radio transmitter against the case.
  • necatduman
    replied
    As I think the counter in front of the counter circuit in the logistics of putting this circuit should stop or slow down the counter or frequency when a high light that wonder
  • chth96
    Is it possible to test small ceramic disc capacitor with analogue meter?
    by chth96
    I read EBOOK of Testing Electronic Component and found that
    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
    Is it really possible to test small ceramic disc capacitor with analogue...
    03-09-2024, 10:03 PM
  • x_orange90_x
    Seven Leagues Slot Machine stop button issues
    by x_orange90_x
    I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
    The issue now is the Stop buttons are intermittently...
    02-12-2025, 10:01 AM
    Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
    by sam_sam_sam
    I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
    I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
    12-31-2023, 06:04 AM
  • jorpec
    Changing the scale of an analog meter
    by jorpec
    Hi
    I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
    I wonder how i can accomplish this so the meter would be precise at any temperature ?
    Thnaks
    01-23-2023, 10:37 AM
  • Stephan Mathers
    EDMI ATLAS MK10 Electronic Meter Discussion
    by Stephan Mathers
    Greetings, new guy here but always interested in the crazy universe of modding
    We just finished construction of around 25 vacation houses, all inside the same private area.
    Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
    The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
    Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
    05-20-2025, 09:09 AM
