Enlight GPS-350CN-101
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    I've not had my hands on an Enlight power supply before, and this one seems an impressive build, with beautifully soldered PCB
    Let down by the larger 'crapacitor' in the secondaries, a Capxon - others seem to be LTEC
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • mockingbird
    • Dec 2008
    • 5488
    Re: Enlight GPS-350CN-101
    It's the same one like in this thread...
    Interesting... So Enlight used Delta later on as an OEM. I wonder which case of theirs this came in (I'm not aware of Enlight selling PSUs without cases).
    • Wester547
      • Nov 2011
      • 1268
      • USA.
      As usual, the one CapXon on the secondary is bulging and leaking electrolyte. Delta seem to spread around UCC, Nichicon, Rubycon, Ltec, Taicon, and CapXon as though they were all equal in quality...
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        You should consider removing some of the glue, especially from the hot zones of the power supply.
        Keep an eye on the B647 PNP transistor located under the 3.3V toroid coil. Mine was covered in glue and got toasty, tripping the psu protections every time it tried to switch on.
        I notice that your unit as well comes without an extra daughterboard and passive PFC coil.
        Please, can you post a photo of the fan label? The Delta GPS-350 I got for free had its own removed.
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          I knew I should have tested it first, so I was working from a known position
          Having replaced the offending Capxon with a Panasonic FC recycled from a defunct motherboard, it now won't power on
          The Panasonic showed .00 on Dick Smith ESR meter, and ~2100uf on UT61E
          I've forgotten the exact amount, but 5VSB measures well over 6V
          What should I check now ?
          Pic as requested, and pics of replacement
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            Assuming Enlight cases are made from decent metal, I doubt it was an Enlight case from which this came
            It was a flimsy generic case, pop-riveted together
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              I looked at the plastic front cover of that "flimsy generic case" after my previous post
              Should have done it before - because moulded inside it says "Enlight PM2402"
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                First, fix the 5vsb overshoot.
                Look at the cap I have circled in the photo attached. This is the 5vsb critical cap. If it goes high esr the 5vsb can go too high and killl the motherboard. Please replace it with good cap and check the 5vsb again.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  I second this. 5VSB measuring in at 6V and up is bad! The first thing I thought when I saw the pics of the PSU guts was, oh no, it's got what looks like a 2 transistor 5VSB circuit
                  Muh-soggy-knee
                  • mockingbird
                    • Dec 2008
                    • 5488
                    Here it is:
                    Looks like their quality went downhill in their later years.
                    Measuring the steel on my 7237, it easily reaches 0.9mm where it's not folded over. But I'm under the impression that even later revisions of old models were built with much thinner steel as well. Mine is from the 90s.
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      Thanks goodpsusearch
                      That Ltec 47uf 25v wouldn't measure on Dick Smith ESR meter, and showed ~28uf on UT61E
                      Only 47uf 25v cap I had on hand was a recycled Licon which did ~1.7 ESR and 47uf
                      Better than some new questionable brand 47uf 50v I also have, at ~1.6 and 40uf
                      So I used the Licon, and 5vsb is now ~5.2v - although if I hold DMM probes in place, it will drop by 0.01 decrements to ~5.1v
                      It still won't start though
                      What next ? - get some decent 47uf 25v caps and replace the lot ?
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        Just replace every small cap in the primary. My unit has 2 x 4.7uF 50V Ltec and the critical cap you already replaced.
                        You should also check every cap and make sure it is in specs.
                        Did you check the TO-92 transistor under the 3.3V toroid? Mine was dead.
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          I checked both 4.7uf 50v caps in the primary, plus another one the other side of the transformer
                          All seemed OK, around 0.14 ESR and 4.5uf
                          The transistor at Q301 also seems OK - testing with Continuity / Diode test of Fluke 77, gives a quick beep with one lead at centre leg and other lead to either side leg
                          I notice fan twitch when I switch power on
                          What should I try now ?
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            Notice that base is not the center leg and that it's PNP, not NPN.
                              • 31284
                              you should have just done a full recap with FR, FK & FC.
                              then taken it from here.
                              if all the electrolytics are good then start metering ceramics for a short.
                              • pfrcom
                                Oldbie
                                • Jun 2006
                                • 1230
                                If DMM shows Zero with Com (Black) to Base and Ohm (Red) to both Emitter & Collector, does this mean transistor is faulty ?
                                  • 31284
                                  maybe, or something connected to it.
                                  are you talking about on-board testing, or off-board?
                                  • pfrcom
                                    Oldbie
                                    • Jun 2006
                                    • 1230
                                    Sorry, should have been clearer
                                    Transistors desoldered from boards, and using method 3 from:
                                    http://www.wikihow.com/Test-a-Transistor
                                    I get ~55 Mohm with Ohm (Red) on Base, but nothing if Com (Black) is on Base
                                    Plural after acquiring another two of these discarded for rubbish collection
                                    • pfrcom
                                      Oldbie
                                      • Jun 2006
                                      • 1230
                                      Anyone ?
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2850
                                        • Greece
                                        diode mode, not ohms
