Here in Greece we don't see Good brand power supplies often. I was excited when I realized the psu I picked up some days ago was a Delta.
Fortunately, the guy who threw it away took the fan only. Could have been worse!
Don't expect too much though! It's a classic half bridge design with 2X 13009 transistors. In TO-3P package though!
The primary caps are 2x 680uF 200V Capxon. The transformer seems bigger than ERL-35, What do you think? Is it ERL-39?
The input filter is there, including MOV, but there is no NTC inrush current limiter. There is no PFC either, active or passive.
The bridge rectifier is T8KB 80, but with no heatsink attached to it.
The 5vsb mosfet is K3767.
Output rectifiers:
MBR3045PT @ 3.3V
MBR3045PT @ 5V
2x STPR1620CT =32A @ 12V
SG6105D1Z is used as Supervisor + Regulator + PWM
While every rail has a coil and 2 caps (-12V has coil and 1 cap), 12V has no coil and just one filtering cap.
All the output capacitors are Ltec and appear fine except the one used in 12V which is Capxon GL 2200uF 16V d12.5mm and is bad.
I replaced the bad cap, put a fan on it and tested the psu: 5vsb is there, but when you short green with ground, the psu tries to start for fractions of second and shuts down immediately.
Any help? What should I look for?
Output rectifiers:
MBR3045PT @ 3.3V
MBR3045PT @ 5V
