Apple TDK PSU
  • Chevy2
    • Apr 2012
    • 73
    Apple TDK PSU
    I accidentally fried the inductor on an Apple LC PSU. Can anyone help me locate a replacement? The only part number visible to me is 290A P15.
    Thanks!
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Apple TDK PSU
    thats not the only thing fried! when that goes, something is very wrong!
    Follow the white rabbit.
    • japlytic
      • Oct 2005
      • 2086
      Re: Apple TDK PSU
      The fried component in the picture is a common mode choke for EMI filtering - they should not be all that hard to get in the right size, but current capacity needs to be considered.
      • Chevy2
        • Apr 2012
        • 73
        Re: Apple TDK PSU
        Didn't mention it was plugged in when I tested and it shifted and 110 touched it. The value and a suitable replacement is what I'm having a hard time with.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          Re: Apple TDK PSU
          ok, what are the dimensions of the choke? and lead spacing? also, what's the incoming line amps (or watts?) written on the PSU?
            • 31248
            Re: Apple TDK PSU
            you could pretend it's a no-name pc supply and replace it with a pair of jump-wires.
            • Chevy2
              • Apr 2012
              • 73
              Re: Apple TDK PSU
              The lead spacing is Half inch by 7/16, with the choke not much larger. I've attached a picture of the outside label.
              Thanks!
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                Re: Apple TDK PSU
                this one look about right? http://www.digikey.com/product-detai...0-5-ND/1994023
                if not, can i get actual package size for the choke?
                • addytzu123
                  • Mar 2013
                  • 54
                  • ROMANIA
                  Re: Apple TDK PSU
                  Looking at the picture, there is also a component that might be a varistor, wich is split in half (or so it looks).
                  In a transistor circuit protected by a fuse, the transistor will always blow to protect the fuse.
                  • Chevy2
                    • Apr 2012
                    • 73
                    Re: Apple TDK PSU
                    Adding a picture to double check..everything appears ok to me.
                    • Chevy2
                      • Apr 2012
                      • 73
                      Re: Apple TDK PSU
                      It looks exactly like it, but how do I know which mH and amperage to get?
                      Its approx. 20mm long x 21mm height x 16mm width
                      Lead spacing is 13mm x 10mm
                      • addytzu123
                        • Mar 2013
                        • 54
                        • ROMANIA
                        Re: Apple TDK PSU
                        I pointed the suspect component below. Could you check if it's a crack or just paint line..
                          • 31248
                          Re: Apple TDK PSU
                          looks like a crack.
                          • Chevy2
                            • Apr 2012
                            • 73
                            Re: Apple TDK PSU
                            I think it was just a molding line. I looked again and it looks ok. Any guess on at the mH that I should replace this with?
                            • kaboom
                              "Oh, Grouchy!"
                              • Jan 2011
                              • 2507
                              Re: Apple TDK PSU
                              For testing only:
                              Jump the choke out and make sure the supply still comes up.
                              "pokemon go... to hell!"
                              EOL it...
                              All style and no substance.
                              guilty,guilty,guilty,guilty!
                              guilty of being cheap-made!
                              • Chevy2
                                • Apr 2012
                                • 73
                                Re: Apple TDK PSU
                                Originally posted by kaboom
                                For testing only:
                                Computer booted just fine with it jumpered.
                                • Chevy2
                                  • Apr 2012
                                  • 73
                                  Re: Apple TDK PSU
                                  Are you saying that this is a safe replacement and the one to get? Want to be sure before ordering.
                                  • berniedd
                                    • Mar 2007
                                    • 119
                                    Re: Apple TDK PSU
                                    Have you considered just rewinding it?
                                    • Chevy2
                                      • Apr 2012
                                      • 73
                                      Re: Apple TDK PSU
                                      Have never done that before. I'm assuming I'd just be better off picking up a new one.
                                      • Chevy2
                                        • Apr 2012
                                        • 73
                                        Re: Apple TDK PSU
                                        Is it safe to just leave the jumper wires in place and seal it up? Seems to work just fine.
                                        • a_p3rson
                                          Apple Watch Charging Controller Schematics / Boardview - 820-02601
                                          by a_p3rson
                                          Hi there,
                                          I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                                          You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                                          This daughterboard uses an interesting...
                                          04-21-2025, 11:41 PM
                                          Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                          by momaka
                                          Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                          So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                          09-19-2021, 08:44 PM
                                          HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-12-2024, 02:30 PM
                                          HP EliteBook x360 1030 G4 + Apple AirPods Pro Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 1030 G4 + Apple AirPods Pro Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Apple AirPods Pro boardview and 1030 G4 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-06-2024, 07:50 PM
                                          HP ProBook 450 G7 + Apple AirPods Pro Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G7 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Apple AirPods Pro boardview and 450 G7 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
