Dell Power Supply fan not coming ON
    • Jul 2011
    • 6040
    I am working on Dell computer power supply that was totally Dead
    I found one bloated cap that was a 3300uf @ 16 volts
    I found all of the cap below 100uf @ ten X the ESR value that the new ones are of that value
    I recapped the power supply except the two main caps
    The cooling fan dose not even tiwitch or move at all
    If I need to post photos of this power supply I can but it will have to be later
    • Jul 2011
    • 6040
    Re: Dell Power Supply fan not coming ON
    I will check the fan on another power supply to see if it works
    If the fan is good ?
    What to check next?
      • 31072
      follow the fan supply, one side is going to be ground the other is 12v.
      and one is probably going through a transistor to control the speed.
      replace the transistor with a jump-wire.
        • Jul 2011
        • 6040
        Thanks for your reply
        I thought that might be the way they did that or with a thermistor which could also be be bad because I saw one those in there as well what are the ohm value of them as a rule of thumb
          • 31072
          no idea,
          the inline thermister is a design i'v not seen in years btw, if it's using one then it probably drives a transistor.
          they can use a smaller one that way.
          • selldoor
            Slow Learner
            • 7870
            SAM if you are trying to start it with a paperclip on the bench this might be of interest.
            https://www.badcaps.net/forum/showth...ell#post222675
              • Jul 2011
              • 6040
              The power supply comes ON and works
              The fan is the only thing that is not working
              • selldoor
                Slow Learner
                • 7870
                OK did you test the fan yet? or the voltage at the pins.
                I am not sure if there is a standard for thermistors - is the one you see related to the fan or is it current inrush near the mains socket.
                I have seen a table of some NTC thermistors which suggest 3000 ohms at 70c
                and goes to zero at 90c but depending on use I suppose the figures could be anything as long as it reached zero ohms at the temperature full speed was required.
                Here is a way to test if it actually works at all
                http://www.ehow.com/how_5398454_test-thermistor.html
