Motorola SBV5220 Squaling PSU
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    I scored a motorola SBV5220 cable/telephony modem for $2.50 today... and it squeals.
    The noise is coming from the internal PSU, a 14V unit from delta.
    unplugging the PSU from the rest of the system lessens but doesn't eliminate the noise, which leads me to believe it's secondary capacitor issue. However, the caps in the PSU are all name brand, the main a nichicon PW. The other three lytics in the PSU are another nichicon PW and two rubycon YXFs. The primary cap, FWIW, is a panny of some sort (glued down), but being a high pitched squeal, I'd think it to be a secondary issue.
    Recap the PSU anyway?
    PS- the other caps in the modem are all taicons, which I'm not sure if I'll replace yet...
    sigpic
    (Insert witty quote here)
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Motorola SBV5220 Squaling PSU
    i would replace all the lytics.
    think about how many hours it will have run by now.
    and how tired all those caps are.
    • everell
      • Jan 2009
      • 1514
      The last squealing power supply I worked on had bad switching transistors. They worked, but they sang to me. I replaced them and the squealing disappeared. Some of those Asian made transistors are very questionable.....
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Noted. I'll nab those and the lytics too once my pay comes on Wednesday.
        Pretty old unit, copyright 2005... and to think it's replacing a much newer looking Arris unit from bleeping time warner... any idea if this will be able to do 20mbs (what the current plan is rated for)?
        sigpic
          • 31161
          https://cdn.badcaps-static.com/pdfs/...0b3593f20b.pdf
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Been there, saw that, made no mention of max speed (or any real specs for that matter).
            sigpic
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Did some research, It's either DOCSIS 2.0 or DOCSIS 3.0. 2.0 was released in 2001, 3.0 in 2006. The unit is copyright 2005, but usually the copyrights on PCBs themselves predate the unit.
              Either way, it will probably work fine for what my parents are doing... once I get it fixed up, hopefully TWC will let me give them the new MAC adresses w/o a service call (which would be BULLSHIT).
              sigpic
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                If you have more than one upstream/downstream RF channel, "bonded," it's running in DOCSIS 3.
                DOCSIS 2 tops out over 30 mbps, but on a per-node basis.
                Unless the cable plant is "fiber deep," with nodes every block or two, DOCSIS 2 won't cut it.
                "pokemon go... to hell!"
                EOL it...
                All style and no substance.
                guilty,guilty,guilty,guilty!
                guilty of being cheap-made!
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  ^true (I do know they switched modems when we upgraded from 10mbps) ... Now to figure out which this unit is...
                  edit- it's a 2.0. Damn. paperweight.
                  sigpic
                    • 31161
                    look for a motorola "frog" modem.
                    we used to have loads of them in europe before docsis routers got cheap.
                    they were supplied with a linksys router as a combo.
                    • kaboom
                      "Oh, Grouchy!"
                      • Jan 2011
                      • 2507
                      Depends on the bandplan and modulation capabilities of the CMTS.
                      You'll have a block of channels (up/down) that support the modulation used for DOCSIS 3, which are "reserved" for that by default.
                      There can also be a few channels, for backwards compatibility, still set to support the older modulation, which are there for the old stuff.
                      Now if there are many customers with DOCSIS 2 equipment on your particular node, and just a few channels to go around, and that's the only node for a few miles, you may notice slowness during peak hours. This is not strictly a DOCSIS 2 issue- simply too few channels supporting the modulation your modem happens to require.
                      If TWC pushes fiber deep, there should be plenty of nodes around; so even with limited DOCSIS 2 channels, the aggragate bandwidth available is much higher than an old school system, with maybe a node every few miles.
                      SECV has a fiber deep, hybrid system, with nodes every few blocks- DOCSIS 2 is no problem. Lousy "consumer grade" routers are more of a problem here.
                      To get a rough idea of how far they're pushing fiber, look for these "snowshoes" on the poles.
                      http://www.qualitycable.com/LL_FIBOPTSS_.htm
                      It will probably still work. Try 192.168.100.1 to it, after hooking it to the cable system.
                      You'll at least be able to see if it locked on to any available channels. You should be able to see this even if the MAC hasn't been whitelisted. The RF side has to work long before it goes "online."
                      EOL it...
                      • DrewPhillips
                        Capacitor Diarrhea - Nichicon PL Series
                        by DrewPhillips
                        Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                        The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                        03-02-2025, 10:18 PM
                      • nick3092
                        Mid/late 80's Nichicon Yellow Caps
                        by nick3092
                        I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                        08-28-2022, 03:56 PM
                      • CapLeaker
                        Motorola 22F43 14pin dip identify me
                        by CapLeaker
                        Got an old Motorola page out controller here. Something honking old. Came in as no workie. Without schematic or anything. So I did some probing around and found two 14 pin DIP IC's that I need an replacement for.
                        Motorola 22F43
                        Motorola 22F44
                        Got no idea what these are.I got semi lucky and found a 22F44 on a donor. Unfortunately the 22F43 is already missing. If anybody knows what these are and find a cross would be greatly appreciated!
                        01-21-2024, 09:12 AM
                      • chth96
                        Is there datasheet for nichicon LXJ series?
                        by chth96
                        I want to calculate capacitor ESR referring to below guide.
                        https://forum.digikey.com/t/calculat...-from-tan/2633
                        I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                        I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                        Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                        11-20-2022, 08:11 AM
                      • chth96
                        Is there any datasheet for nichicon RT(M) series?
                        by chth96
                        A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                        https://www.badcaps.net/forum/troubl...e-been-blew-up
                        and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                        But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                        I have spare console...
                        11-28-2023, 03:36 AM
