Please help me understand\fix this discrete linear power supply
    Re: Please help me understand\fix this discrete linear power supply
    Rievax, thanks for that great handbook, so it does look like he need to have low Vf diode (page 21, fig 14) for that purpose.
    Learning something everyday here. I will that in my troubleshooting guide thread.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      Originally posted by budm
      May be add the diode on the output of the 7805 (Anode to the output PIN OF 7805, Cathode is the out put) so that will isolate the output of 7805, the out put will be 0.6V lower but you can fix that by adding the forward bias diode and the small bypass cap in parallel between GND pin of the 7805 and GND.
      Originally posted by fzabkar
      Like this?
      Code:
             ____
             |  |  Do
          o-----|7805|--->|---+----o V+
             |____|    |
            Dg V --- C  - D430
          o-------+---+-------+----o Gnd
      Yes.
      No. The negative rail is attempting to pull, thru the opamp, from the positive supply. A diode in series with the + output will still result in current coming out of that 7805!
      You need a schottkey diode from GND to the output of that 7805; anode to GND, cathode to +5.
      Instead of the backfeed coming out of the 7805, with its .7V drop, that current will now go around it, thru the schottkey. The lower junction drop of this schottkey bypass diode will take the 7805 out of this path, allowing it to start- the "fault" current is bypassed away from that 7805.
      +7 is slow to come up, not because of some "mysteriously slow" transistors, but because of a bypass cap (C306, 2.2u) from +7 to the wiper of P300. It causes the regulator to back down on any sudden positive-going noise on the +7 rail.
      But it also slows down the rate-of-rise when the thing's powered up with all caps discharged. When power is first applied, pin 3 on U300 is effectively tied right to the output, until C306 charges. After that, the pot and resistive divider take over to provide an accurate sample of +7.
      The -7 output has a similar soft-start, but notice one thing! C307 is only 1u. And the resistors are different values, also giving a different time constant.
      Increase C307 to 2.2/50, or even 4.7/50 to slow down the rate-of-rise for -7, while keeping that of +7 the same.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
        I just read the explanation from RIEVAX Handbook that explains the function of that low Vf diode on the output.
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          But the rate-of-rise of -7 can also be slowed down if need be, by increasing C307. Giving that 7805 section time to "catch up."
          EOL it...
            But I still wonder why the units works before, or maybe the problem never show up during the final test before the products are released, or it is marginal so any parts that change its value by small amount caused this symptom to show up.
            I am sure there must be lot of these units out there with the same problem.
            • fzabkar
              • Mar 2009
              • 772
              FWIW, I notice that the parts list specifies a 1N4148 for D403 whereas Fig 4.2 in the handbook calls for a Schottky diode.
              BTW the handbook was a revelation too me, too.
                BTW, if we do any slow down on the startup of the power supply, I.E slow down the -7V, to me that will create the problem for the 7905 too, trying to make power supply to come up at the same time is not practical, adding the diode to both 7905 and 7805 seems to be the correct approach as shown in the handbook.
                  • 31015
                  But I still wonder why the units works before, or maybe the problem never show up during the final test before the products are released,.
                  your knowlege of Sinclair is lacking,
                  they make a habit of selling stuff with terrible over-complex power circuits, then constantly revising them.
                  the Sinclair spectrum computer had 7 major revisions requiring pcb changes, and several intermediate changes with parts bridged on the pcb!
                  all to make THIS actually work.
                  • kaboom
                    "Oh, Grouchy!"
                    • Jan 2011
                    • 2507
                    Plus, the supposed service manual for Agen24's unit didn't even show all the GNDs/commons/returns bonded/tied together- in the power supply no less! Hence his initial troubles with the "V5POS" running away.
                    I've seen it before:
                    "Wheeee! Run wild, little power supply!"
                    EOL it...
                      What about Sinclair? Is this UNIT MADE BY SINCLAIR, same as Sinclair computer, excuse my ignorant! I do not see SINCLAIR name any where in the service manual, except the hand written SINCLAIR on the first page, otherwise I see the name MAURITRON.
                      • kaboom
                        "Oh, Grouchy!"
                        • Jan 2011
                        • 2507
                        Ideally, both supplies would come up at the same time; tweaking those two softstart caps will change this... The diodes are always added as a "backup" anyway, but they must have a lower Vf than the unwanted path thru the 78xx's.
                        EOL it...
                          "Ideally," That is the key word.
                          • kaboom
                            "Oh, Grouchy!"
                            • Jan 2011
                            • 2507
                            Those diodes are your friends...
                            EOL it...
                              Yep, after reading that handbook, thanks to RIEVAX.
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                #95
                                If D403 is a 1N4148, Then replacing it with a larger silicon diode might be enough. Power diodes with low voltage ratings are supposed to have a lower forward drop.
                                • kaboom
                                  "Oh, Grouchy!"
                                  • Jan 2011
                                  • 2507
                                  4148s and 400x diodes are silicon not shottkey (half-junction), with a nominal .7V drop- the same as the "backfeed drop" thru that 7805.
                                  We must have a bypass diode whose Vf is lower than the reverse-backfeed drop of the 7805, so the diode turns on first and completely shunts the current around the 7805, allowing it to bias properly. The path thru the 7805 stays open til about .7V; a shunt path whose Vf is lower than that makes the 7805-reverse-path effectively nonexistent.
                                  EOL it...
                                    "We must have a bypass diode whose Vf is lower than the reverse-backfeed drop of the 7805" So what is the level of this reverse-backfeed drop of the 7805?
                                    • kaboom
                                      "Oh, Grouchy!"
                                      • Jan 2011
                                      • 2507
                                      Originally posted by Agent24
                                      The rail in question feeds from the main +7v rail and uses a 78L05 to generate the +5vA rail. So far so good, but it doesn't always come up. When it works, it's perfectly stable at 5v, when it doesn't work, it strangely shows -0.77 volts. (I would have expected zero).
                                      -.77V for the OP.
                                      Current was coming up from GND, into the 78L05's GND pin, back out the output pin, from the +5 to -5 rails.
                                      -5 came up first.
                                      When rail-to-rail (w/o GND connections) loads were removed, that 78L05 always came up.
                                      EOL it...
                                        -.77V for the OP.
                                        -5 came up first.
                                        Thanks, I just read more in details of the hand book chapter 2.
                                        "There is a point to heed in applying power supply ICs. It is that a method known as "junction separation" is used
                                        as the method of electrically separating each of the elements above. By connecting a separation region so that it is
                                        formed by a P-type semiconductor and is the same lowest potential as the substrate, the element region and the
                                        separation region are electrically separated and insulated by being in (PN junction) reverse bias states. If for some
                                        reason the potential of this separation region becomes a higher potential than the element region (for example the
                                        NPN transistor collector region in Figure 2-1), normal operation cannot be expected since the PN junction enters a
                                        forward bias state and the separation state between the elements cannot be maintained. For example, when using a
                                        positive output three-terminal regulator, the GND pin always must be made a lower potential than the potential of
                                        other pins."
                                        So the diode that I suggest to put in at the output, since the Diode to GND is clamp to 0.6V by that d403, so the added diode to the output in series as I suggested should not be on then and prevent the back feed based on this block diagram? I will do some experiment in the lab.
                                        • rievax_60
                                          • May 2012
                                          • 897
                                          • australia
                                          #100
                                          Yes, that would work if the extra drop out voltage can be spared.
                                          Larger silicon diodes have a lower forward drop for a given current than smaller silicon diodes do.
                                          A schottky diode is a much better option if available.
                                          • Nagy Daniel
                                            Lowest possible resistance on laptop motherboard rail - Guide Table request
                                            by Nagy Daniel
                                            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                            So, I generated a table with AI so I can...
                                            03-04-2025, 08:24 AM
                                          • jinu_j
                                            by jinu_j
                                            Hi
                                            05-03-2025, 10:51 PM
                                          • MidnightRoller
                                            Can a resistor lose resistance after hot air?
                                            by MidnightRoller
                                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                            02-02-2022, 11:46 PM
                                          • Victor Moreira Silva
                                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                            by Victor Moreira Silva
                                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                            Well, my decice specs are the following:
                                            Model: Acer Nitro 5 AN517-54-55T5
                                            CPU: Intel Core i5-11400H
                                            GPU: NVIDIA GeForce GTX 1650
                                            Motherboard: GH51G LA-L181P Rev:1c
                                            The symptom:
                                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                            05-26-2025, 10:49 AM
                                          • artvandalai
                                            What resistor ohm will work better to repair this waterpik?
                                            by artvandalai
                                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                            01-05-2025, 04:10 PM
