Hi everbybody!
I Have a VGA monitor HP1502 and the failure is NO POWER. No led, no Power, nothing. The power board is a 715L1034-1
So I tried to find some diagrams o Service manuals and I found those PDFs :
In the HP L1502 Service Manual.pdf attached document, I can see the power board doesn't match with the 715L1034-1. Very interesting for fixing the scaling board but in my case it's useless...
In the 715L1034-1 Diagram.pdf attached document, there is the complete diagram of the 715L1034-1 power suppply board, exactly at page #34-35.
So I started to make the following basic changes on the board:
Replaced Q903 - K2996 Mosfet Transistor
Replaced IC901 - SG6841 PWM Controller
Replaced IC902 - PC123 OptoCupler
Replaced Q901 - A733 PNP Transistor
Replaced Q902 - K945 NPN Transistor
Following with no power result
I'm living in Mexico so I have 120VAC @ 60 Hz.
All the results of these meditions are maked with the board disconected of the scaling board (This one do the gestion of the POWER switch)
The rectifier of the primary of the power supply board seems to be OK. At the output of the diode bridge I have 170VDC.
Now I'm checking around the PWM Controller SG6841. (PDF Attached).
Pin 1 - GND - Looks to be OK
Pin 2 - FeedBack - 0V (Nothing) - At oscilloscope 0V (Nothing)
Pin 3 - Vin - 0,75VDC
Pin 4 - Reference Settings - 0V (Nothing) - At oscilloscope 0V (Nothing)
Pin 5 - Temperature Protection - 0V (Nothing) - At oscilloscope 0V (Nothing)
Pin 6 - Current Sense - 0V (Nothing) - At oscilloscope 0V (Nothing)
Pin 7 - Power supply - 0.04VDC (The problen shoud be there? The IC is unpowered?)
Pin 8 - Drive Output - 0V (Nothing) - At oscilloscope 0V (Nothing) - I shoud have a square signal here I think...
Now I will check the outputs of the 715L1034-1 power supply board:
Pin 4 Shoud give 5V permanent - And I have 0V - Nothing
Where I can look to fix this board?
Regads, Axel.
Regads, Axel.
